Old 09-11-2006   #1
HKSenilyks
Send a message via AIM to HKSenilyks
Bore
I'm thinking about boriing my block, What gains will there be from doing so? Would it be worth it if I don't make it a stroker?
HKSenilyks is offline   Reply With Quote
Old 09-11-2006   #2
Re: Bore
If you don't know the gains, I suggest you take it to somebody who does.
Boring out a block is for the soul purpose of moving up to the next size larger pistons. We do this for several reasons, scoring in the cylinder walls, seizing the piston in the block, cylinder worn too far out of round, etc.
As for stoking it, people have stroked engines on stock bores.
Old 09-11-2006   #3
HKSenilyks
Re: Bore
So just boring my block (with the correct size pistons) won't change how my motor performs?
Thaught
Old 09-11-2006   #4
Re: Bore
Not really, unless there is a problem with your engine that requires it.
Old 09-11-2006   #5
Thor06
11 Seconds to Freedom
Thor06's Avatar
Re: Bore
There will be a small displacement gain but not enought to mean anything. If you are rebuilding, I would personally do it whether it really needs it or not. I would rather spend the extra couple bucks on some new pistons and a bore out just to be sure.
Old 09-12-2006   #6
HKSenilyks
Re: Bore
See this is my first rebuild, I bought a shell a few weeks back and i was thinking, "well if boring my cylinders will be a bit stronger, why not". I just dont want to build my motor to break.
Thaught
Old 09-12-2006   #7
Re: Bore
Boring your cylinders makes them weaker. Going .020" over is such a small displacement gain that any horsepower gains from it would be hard to even notice. How the new rings seat will possibly have a bigger effect on how the new motor performed. If you went from stock bore to something like .080", then you might seeing some performance gains from the increase in displacement, but you can't go too far before the cylinder walls are too thin for high HP.
Old 09-12-2006   #8
Re: Bore
If you can bottle hone it and throw the stock pistons back in with new rings, you'll be in good shape in more ways than one.
Old 09-12-2006   #9
Re: Bore
Unless the cylinder bores are f-ed up, you might as well just lightly hone the cylinders, and use the stock size pistons. And if you're considering stroking the engine (i.e. 2.3L), why not just go to a 2.4L block?
Old 09-12-2006   #10
JiggahMan
Re: Bore
Tits, if you're using the block that's sitting in the garage. Get it bored and honed, it needs it.
JiggahMan is offline   Reply With Quote
Old 09-12-2006   #11
HKSenilyks
Re: Bore
Yea I was thinking i would any way its got a little scoring on it. .30 what do you guys think
Thaught
Old 09-12-2006   #12
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Re: Bore
If you do any overbore do .020
Old 09-13-2006   #13
HKSenilyks
Re: Bore
.20 alright
Thaught
Old 09-16-2006   #14
Thor06
Thor06's Avatar
Re: Bore
Jake (EclipseGST) once told me that 2.0 blocks can go out quite a ways. 2.4 and 2.0 blocks use the same casting and the bore of the 2.0 blocks is 85mm while the 2.4 is 86mm. He says hes seen 2.4's go over .040 so you should be able to go .040 over on a 2.0 block and still be perfectly fine.
If you can get away with just honing and new rings by all means do that but I wouldnt be scared of boring the shit out if you have to especially if you only go out .020.
Old 09-16-2006   #15
Re: Bore
2.0 and 2.4 blocks are certainly not the same casting. their deck heights differ by like 6mm!
Old 09-18-2006   #16
HKSenilyks
Re: Bore
I'm just trying to build a 2.0 right now. Once my cars running I'm going to start on a stroker.
Thaught
Old 09-18-2006   #17
Re: Bore
Why build two? Build one right the first time.
Old 09-18-2006   #18
Re: Bore
And why couldn't the 2.0 just be a smaller bore and be milled down 6mm more? It's only 1/4", which is 2 passes on cast iron. Maybe 45 seconds of machine time.
Old 09-19-2006   #19
HKSenilyks
Re: Bore
I'd love to and am still thinking about it, but theres one problem, $$$.
Thaught
Old 09-19-2006   #20
Re: Bore
It might be real similar to a NT 2.0 block, but not a turbo block. Things like oil squirters and a knock sensor hole.
If you're going to build a motor with aftermarket pistons and rods, it's not any more expensive to just build a 2.4. But I wouldn't go more than .020 on a 2.4 block, there's been more than a few cases of cracked cylinders, like Momin's. You can bore the hell out of a 2.0, .060 is not unheard of.
