Old 09-13-2006   #1
ExTREME
ExTREME's Avatar
Headliner..
Wondering what I should use to put the new fabric on my headliner on? I pulled out my saggy headline because I didnt want to rock pins. Any suggestions? any pics of some nice headliners would be helpful.
SA
Old 09-13-2006   #2
Re: Headliner..
I believe there is a special headliner glue you can buy at the auto parts store.
Old 09-13-2006   #3
ExTREME
ExTREME's Avatar
Re: Headliner..
Ran down to napa and they only had 1 can of Spray Adhesive, looks like glue when you spray it out, not thick but its solid. Do i cake this on or lightly coat it? anyon eknow?
Also, would it be a spendy idea to put diamondplate on the sides of the doorpanes where that stock carpet/speaker is located? anyone know where I can buy diamondplate online preferably?
Thanks
Old 09-13-2006   #4
Re: Headliner..
Use a thin coat of that glue.
Old 09-13-2006   #5
f0urtyfive
Re: Headliner..
where did u find a new headliner?
f0urtyfive is offline   Reply With Quote
Old 09-13-2006   #6
Re: Headliner..
3m makes a good spray adhesive. Put a very thin coat on both items being glued together, let dry for 10 minutes and then put it on using a small roller or something to push the fabric up.
Old 09-13-2006   #7
Re: Headliner..
Just follow what this guy did: http://www.mnsportcompacts.net/forum...ghlight=mayjor
hahaha
Old 09-13-2006   #8
Black97civic
35mpg
Re: Headliner..
3m makes some good spray shit that I have known people to have good luck with.
Old 09-13-2006   #9
ExTREME
ExTREME's Avatar
Re: Headliner..
Didn't get a new headliner, took my saggy droopy one down and pulled the material off, going to get some new fabric and roll it on.
Old 09-13-2006   #10
Re: Headliner..
Um yeah, diamond plate is fucking expensive. Why the hell would you want diamond plate on your doors anyway? Buying diamond plate online? I'd hate to see those shipping costs. Go to your local welding shop and see what they can get for you. Anytime I have worked with diamond plate I have gotten it in a sheet from a metal supply warehouse.
Old 09-13-2006   #11
ExTREME
ExTREME's Avatar
Re: Headliner..
I just want to get rid of the carpet on the doors, with something hard, diamondplate came to mind first, I have some 1/8" aluminum but i dont know how well that would look without protruding 3d. Maybe spray it and put it in, I dont know, pipe dreams from this morning i guess.
Old 09-13-2006   #12
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
Re: Headliner..
I replaced the headliner in my 2g a while ago. I can't think of what the material I used is called, but they make actual headliner material at joan fabrics. My headliner is really sagging down on the sides because I either didn't use enough adhesive or I pulled it too tight. So be careful about that. Any other questions just pm me.
pics or gtfo
Old 09-14-2006   #13
Re: Headliner..
What happened to that Jeff's Custom Upholstry that people had good luck with a few years ago?
Old 09-14-2006   #14
xveganxcowboyx
Wanker
xveganxcowboyx's Avatar
Drives: 95 M3
Re: Headliner..
I also picked some up at Jo-Ann fabric. $15 for more than enough to do my car (maybe twice over). It's colored fabric with a layer of foam which will absorb the glue so it doesn't show through. They also sell a couple kinds of spray glue.
Now if I could only get around to doing the work...
Old 09-15-2006   #15
HiImBrian
HiImBrian's Avatar
Re: Headliner..
lots of glue is good. It usually takes a while for it to get sticky, so spray and wait like 30 seconds.
pics or gtfo
Old 09-15-2006   #16
Re: Headliner..
I got some glue I keep tacking the low spots on..it holds really well. I, however want to re-cover the headliner/eliminate the sun visors (cleaner look ihmo). Anyone have a roll of black laying around they don't need, big enough for a 1g? If there is a hole in the middle that's fine, I have one of those dumb sun roof thingys.
-A. Swift
Old 09-15-2006   #17
Re: Headliner..
3m Super 88 works very well for attaching head liners.
Old 09-16-2006   #18
xveganxcowboyx
Wanker
Drives: 95 M3
Re: Headliner..
-A. Swift
If I have any left after I do mine I'll let you know. Otherwise Jo-Anne's in Midway has it.
Old 09-17-2006   #19
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Re: Headliner..
Hey I just replaced my headliner this summer and may have a couple of hints
Don't use the NAPA stuff, junk
I tried using that and it just fell off
Bought 3M stuff and works much better
I also bought my fabric from Jo-Anne because they accually have fabric for headliners
Before you do any of that, make sure to take a wire brush and scrape the old foam off.
