Old 09-14-2006   #1
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
??? On piston location
Are pistons 1 and 4 supposed to be the same height and 2 and 3 supposed to be the same height when sitting in the block?
Here some pics
http://www.cardomain.com/member_page...65_57_full.jpg
http://www.cardomain.com/member_page...65_59_full.jpg
Is my head still good? Is the damage just to that rod?
Old 09-14-2006   #2
turbo2086
turbo2086's Avatar
Send a message via MSN to turbo2086
Re: ??? On piston location
Yep
turbo2086 is offline   Reply With Quote
Old 09-14-2006   #3
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
so if Im looking at the block while its in the car the 2 and three are diffrent height what did I break
Old 09-14-2006   #4
Maybe you bent a rod. Or your perception of reality.
Old 09-14-2006   #5
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Thats what I was thinking a rod Ill have pics up in a second
Old 09-14-2006   #6
Yea, your shit is broke. Is the head all smashed up?
Old 09-14-2006   #7
xveganxcowboyx
Wanker
xveganxcowboyx's Avatar
Drives: 95 M3
It would have to bend pretty far to sit that high. Broken maybe. Seperated from crank. I'm inexperienced with internals though, so my guesses are probably crap.
Old 09-14-2006   #8
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Great, I dont know Ill go check the head what should I look for? And what should I take pics of so you can see
Old 09-14-2006   #9
Broken shit?
Old 09-14-2006   #10
Look for carnage, CARNAGE. And post up pics for us to see! Carnage always gets me pumped up!!
Old 09-14-2006   #11
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
All the valve ends look ok, all in original location. I dont know if the rockers and cams could of been damaged by this but they seem to look alright as well. Nothing fell out of the head when I removed it.
Old 09-14-2006   #12
I had a head with 10 bent valves once, and it looked fine too. You're shit's prolly f-ed. Lets see pics.
Old 09-14-2006   #14
YiNYaNg
Hold Alt & press F4...LoL
YiNYaNg's Avatar
How that happen?
YiNYaNg is offline   Reply With Quote
Old 09-15-2006   #15
GREASEMONKEY
GREASEMONKEY's Avatar
Moon Lander Champion!
Drives: 92 TSi
Something is definatly broke! The rod is either broke or bent and i cant tell anything on the head though.
Old 09-15-2006   #16
acidrumz
seems to me like piston 1 and 4 don't look too great on the head. black deposits.
most likely your connecting rods are bent. expect lots of surprises in that oil pan.
good luck
yy
Old 09-15-2006   #17
Broken #3 rod, otherwise known as "your shit is fubar'd"
Old 09-15-2006   #18
Motor's gone, start over.
Old 09-15-2006   #19
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
I like your thinking!!!
Yeap I pushed down on piston #3 and it sunk down so conneting rod is snaped.
Old 09-15-2006   #20
Carnage!! Yes!!
