Old 09-20-2006   #1
blageo23
AWD4G64
blageo23's Avatar
IAT Sensor Placement
I have my IAT(Inatke Air Temp GM sensor for AEM EMS) in the TB elbow. Is that a bad place for it becuase of heat soak? Where is a better place to put it if thats not a good place? or how can I make it work on the TB elbow?
Thanks,
Mike
Old 09-20-2006   #2
Re: IAT Sensor Placement
What kind of elbow are you using? It'd probably be better if you put it in your upper intercooler pipe just before the elbow. Thats where most of us put ours.
Old 09-21-2006   #3
blageo23
AWD4G64
blageo23's Avatar
Stock 2G elbow.
Old 09-21-2006   #4
How much heat soak do you think you're going to get at the TB?
Old 09-21-2006   #5
blageo23
AWD4G64
blageo23's Avatar
I have no idea! I dont even really know what the means. I just heard that if can happen. Im clueless
Old 09-21-2006   #6
The stock 2G elbow might be a little thicker than your normal intercooler piping and it isn't seperated from the hot intake manifold by a silicon coupler, so it might be more likely to suffer from heat soak.
Old 09-21-2006   #7
The sensor will become hot from the TB elbo and not give an accurate air temp reading to your EMS. Put the temp sensor in your UICP normaly between your BOV and TB elbo.
Old 09-21-2006   #8
blageo23
AWD4G64
blageo23's Avatar
What about trying to reduce the intake manifold temp. Like this http://www.magnusmotorsports.com/oth...ucts/index.htm (bottom thing)
Im not sure if it would work but couldnt it reduce the manifold temp thus reducing the risk of heat soak?
Old 09-22-2006   #9
That is a good idea also, just put your IAT into you upper pipe like everyone else.
Old 09-22-2006   #10
mike55112
mike55112's Avatar
Drives: 04 evo
Well that would cost me money, I gotta get a block off fitting and a new bung and have it welded in. Just trying to see if it is that big of a deal.
-Blageo23
Old 09-22-2006   #11
Have Justice Brothers weld it for you
