Old 09-27-2006   #1
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Cylinder head rebuild questions
So ever since I bought the car there has been valve tick in the head above 5000 RPM. Also I think the valve guides are shot as well because there is black coating on the inside of my exhaust tip which means I am burning oil somewhere.
Basicly my cylinder head needs a rebuild or something or it is going to drive me crazy.
I was just wondering what is the best way or process to do a rebuild? I have a very limited budget and can do as much work as I can but doesn't a machine shop have to do some of the work? How can I make this process easier for him and cheaper for me?
How much will all this cost?
What Machine shop do you recomend?
Or should I skip all of this and find someone with a different cylinder head for sale? (Would I really know what I am getting?)
Should I wait till the spring and have more money so I can get some other stuff done to the cylinder head?
I am getting some performance parts in the mail however I don't know if I should push the engine with the cylinder head the way it is or am I just over worring?
Thanks!!
Old 09-28-2006   #2
acidrumz
Re: Cylinder head rebuild questions
to get your cylinder head rebuilt, most of the repairs can be done by the machine shop.
remove your ch from the engine. remove the intake. then take the head to the shop.
i recommend you have the head resurfaced, cleaned and new valve stem seals installed.
now is the right time to get some aftermarket head parts if you want to upgrade (revised lifters, cams, springs, valves..)
expect around 180-200 and plus depending what the machine shop finds neccessary to replace (guides, valve job...)
a&k in anoka is my choice. great work.
good luck!
Old 09-28-2006   #3
i would just find another low mile head for like 150-200 bucks.
Old 09-28-2006   #4
Wolf0573
Wolf0573's Avatar
Drives: 1994 Dodge Stealth RT/TT
When I had my head redone it costed me about $350. I had the head boiled, resurfaced, new valve stem seals put in, and the valves grinded and reseated. I had this done at Lloyds Cylinder Head.
Wolf0573 is offline   Reply With Quote
Old 09-28-2006   #5
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
LSE Performance Engines
4g63 head with good customer cores:
Stage 1 head package:
-Head cleaned, carbon removed
-Inspected for cracks
-Resurfaced
-New valve seals
-3 angle valve job
With good core exchange $275
If valve guide work is needed, add $15 per guide.
