Old 10-01-2006   #1
Onefast99gsx
Met my goal at the track today... 11.97 e.t.
Well...my goal has been met, which was 11.99 or better. I went to the Rock today and my first run of the day was my best of the day. 11.97 @ 115mph. This was with the 50 trim @ 25psi. Air temps were good for this run but they quickly went up throughout the day. The head wind got worse as the day went on too with 10-20mph gusts. 60' was 1.70. Not bad for cheap $200 Wanli's. My best is 1.64 on them. I suppose with a couple more psi of boost and a really cool day, I should maybe go 11.80's without issue. It don't really matter though as my goal was met. An aftermarket FPR would help with the consistancy on tuning too. I'm still on the stocker FPR.
60' 1.704
330 4.951
1/8 7.666
1/8mph 93.88
1000 10.006
1/4 11.977
1/4 mph 115.17
Timeslip is attached.
Thanks to all those who have provided me with help on this board!! You're a big help...
Old 10-01-2006   #2
x-pride
x-pride's Avatar
Re: Met my goal at the track today... 11.97 e.t.
Nice time! How much HP are you pushing?
Old 10-01-2006   #3
Onefast99gsx
Thanks. No clue on the HP. Never dyno'd it "YET". Dsmlink calculates close to 400hp on that run but the keyword there is 'calculates'. A couple weeks ago, i was debating on getting a bigger turbo but since this 50trim put me in the 11's, i'm keeping it.
Old 10-01-2006   #4
tim
tim's Avatar
Congrats, very nice.
Old 10-01-2006   #5
Was this on pump gas? Could we get more info on your setup?
tHX
Aaron
Old 10-01-2006   #6
YiNYaNg
Hold Alt & press F4...LoL
YiNYaNg's Avatar
tHX
Aaron
+1
YiNYaNg is offline   Reply With Quote
Old 10-01-2006   #7
Onefast99gsx
114 oct. Cam2 Purple fuel...
Water Injection that is listed below is turned off for race days.
99GSX - PTE 50trim internally gated- PTE 780 INJ - HKS 272 cams - Magnus SMIM - 3" RSR Exhaust - DSMlink v2 - FP 3" intake pipe - TurboXS BOV - Griffin FMIC - Walbro 255lph - Fidanza flywheel - SouthBend DxD OFE clutch - Hallman MBC - Greddy turbo timer - W.Injection - PLX M-250 WB
Full weight '99 GSX. Stock 2g motor except for the HKS cams.
Old 10-02-2006   #8
Thx for the list.
Old 10-02-2006   #9
Nice numbers, welcome to club 11.
Old 10-02-2006   #10
Onefast99gsx
Thanks alot Steve.
There's more in it yet. For some reason i'm getting about 3 deg. of knock in 3rd & 4th gears. This is my first time trying CAM2 Purple 112 octane. My only thoughts are is that maybe 112 just isn't enough for 25 psi. The fuel was newly boughten Saturday.
Old 10-02-2006   #11
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Nice run!
Doesn't it feel great to when you set a goal and then reach it. Now you need to raise the bar (boost and goal )
Old 10-02-2006   #12
Onefast99gsx
Yes, it felt dam good to reach the 11 second club. A few years back it seems if you were running 13's, you were really something and then that became common. Many people are running 12's now. It just seems like you have to run 11's or better nowdays to even stand out anymore. I'm not sure about setting new goals. If anything, it would only be down to 11.50 because i'm not gonna throw a cage in the car.
Old 10-03-2006   #13
112 is fine for 25 psi on most DSM setups. I like C16 for the real boost though.
Old 10-03-2006   #14
Onefast99gsx
Yea for some reason though Sunday i was getting 3 to 3.5* of knock in thru 3rd and 4th gears. Coolant temps were a bit hot though at 210 and 213 thru the traps. I think coolant temps may also give an indication of whats going on in the combustion chamber also.
A few weeks back when i went and got only 1 run in due to rain out, I had some Sunoco Maximal. That's 116 octane. I didn't have any problems then. I only had a couple gallons left so i just mixed it in with the CAM2 112oct.
Probably engine temp is all i can assume at this point.
Old 10-03-2006   #15
If your knock count is high and your coolant temps are high your are detonating, turn the boost down, octane up, or timing down.
Great run's, it is awesome to reach goals (I hope I hit mine this weekend).
