Old 10-04-2006   #1
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Coolant Temp Sensor Question???
I went to go and get a new coolant temp sensor for my 95 talon fwd and absolutely everywhere I went had the wrong one or was not what I needed. I tryed all different years and different sensors and came up with nothing. The only place I have not made it to yet is the mitsu dealer yet. Ill go there tomorrow but I was just wondering if anyone else has run into this?
Old 10-05-2006   #2
95talonracer
Finally Tuned...
Drives: Spyder GSX
Re: Coolant Temp Sensor Question???
Anyone have any ideas?
Old 10-05-2006   #3
It's pretty much a dealer only part. You'd be wasting your time at Pep Boyz.
Old 10-05-2006   #4
Gravy
Who's this guy?
Correction, due to working at Pep Boys in CR i know they have a 1g eclipse temp sensor(or did 2 weeks ago) and the temp sensor for the 1.8 is the same as the 2.0's in 1g's and if you did the 1g swap... that gives you more options.
Try looking into a 1.8, i've got one in my car. No issues or problems as of yet.
Old 10-05-2006   #5
Gravy
Who's this guy?
Oh snap!!!
Sorry for the double post, but i have a 1g radiator with a temp sensor you can have for free if your interested. Came out of the car in perfect working order, and should hold up untill you find a good deal on something else. PM me if your interested.
Old 10-05-2006   #6
95talonracer
Finally Tuned...
Drives: Spyder GSX
No i need a 2g temp sensor. I picked one up from mitsu that is the right one but they charged 55 for it. Let me know if anyone has one of these that they will give away or sell for cheap because I cant afford all these little parts that add up like that. It is a 1g swap so the harness is a 2g so the temp sensor needs to be a 2g.
Old 10-05-2006   #7
Which temp sensor is it? There's three on the 1G's at least, fan turn on and off, temp gauge and ECU input.
Old 10-05-2006   #8
95talonracer
Finally Tuned...
Drives: Spyder GSX
It is the one for the 2g that sends the signal to the ecu. It is kind of a rectangle plug with rounded edges and it has 2 prongs in the middle.
Old 10-27-2006   #9
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
if you still have that 1g temp. sensor your trying to get rid of, ill take it.
