Go Back   MitsuStyle > Hosted Support Forums > DB Performance
Old 10-05-2006   #1
Enes
Enes's Avatar
Wideband
http://dsmstyle.com/forums/sr_classi...hp?do=ad&id=91
can that be setup with DSMLink to log?
-E
Old 10-05-2006   #2
Re: Wideband
Should be able to with the proper voltage to A/F calibration in DSMLink. The gauge has 2 outputs on it. One is the usual 0-5 Volt analog output that you would run to an EMS system. The other is a serial output that can be wired to a DB9 plug and you can use a terminal program like HyperTerminal to see A/F output.
Old 10-05-2006   #3
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Re: Wideband
I have this wideband and I loke it alot. Alot of the guys that I know that have the innovative one or what ever it is said that they like mine alot more. The other one is too bright and cheap looking lights on it. I dont know if you (Enes) were wondering this as well but can this wideband also be a replacement with the seperate outputs for the 02 in our cars? Not trying to steel the thread but just trying to answer more questions about the AEM.
