Old 10-06-2006   #1
tjg
Transmission removal
Ok i got my transmission this moringing and im already tearing the car apart and i was wondering what you got to do to get the tranny out of the car. Are you supposed to drop the subframe, am i suposed to take out the whole suspension on the passenger side, some helpful hints would be great by you guys.
tjg is offline   Reply With Quote
Old 10-06-2006   #2
Tachyon
Tachyon's Avatar
Drives: Icarus
Re: Transmission removal
This is how I do it on my 1g AWD:
1. remove Castle nuts from both front wheel driveshafts.
2. loosen lugnuts on both wheels.
3. jack front end of car up and prop with somthing safe.
4. drain gear oil out of the transmission.
5. while oil is draining, remove front wheels and unbolt the brake calipers on both wheels and use some string or hangers to secure them to the springs so that you don't damage the rubber lines.
6. unbolt the shocks from the hub assembly (both sides).
7. push the drive shafts out of the hub assembly.
8. unbolt support member that runs under your transmission.
9. remove your transfer case and place it on somthing.
10. crawl under the car and remove the center bearing bracket located on the driver side driveshaft.
11. pry the driveshafts out the transmission using a large bladed screwdriver - crawl under car and push the screwdriver in between axel cup and transmission then twist in one swift motion.
12. gently thread your now freed driveshafts out past the wheel hubs and place them in a safe place.
13. unbolt small sheild between oil pan and bell housing on bottom of transmission.
14. remove starter, reverse gear signal wire, clutch cylinder and speedometer cable.
15. support transmission - I use an engine hoist with a cotton rope looped around the transmission, but I used to use a floor jack from the bottom.
16. remove top transmission mounting bracket.
17. remove bolts holding bell housing to engine.
18. grapple the transmission by leaning over the side of the car and tugging it until the input shaft is free of the clutch.
19. lower the transmission to the floor.
20. drink a beer.
That's pritty much it. I just read that you have a 2nd gen so it is probably slightly different then mine, but this should help you get started.
-Sebastian Vettel
Old 10-06-2006   #3
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
Step 1: Read at VFAQ.com (There's one about clutch install for a 2g that also shows tranny removal steps)
Step 2: Get a Repair Manual
Step 3: Ask Questions
Also, it might help if we knew what kinda car it was.. 1g or 2g? FWD or AWD? We need more info.
Old 10-06-2006   #4
tjg
ITs a 2g awd tsi manual
Old 10-06-2006   #5
You need to support the motor on a 2G.
Old 10-06-2006   #6
An engine hoist and a transmission stand are wonderfull tools for this job, even if you need to rent them from someplace.
Old 10-06-2006   #7
munster000
lol
munster000 is offline   Reply With Quote
Old 10-06-2006   #8
tjg
I just got off work, so do i have to drop the subframe on a 2g or no?
Old 10-06-2006   #9
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
After removing tranny fluid, both axles and transfer case there's a big plate/frame ("right member") piece going down the middle of the car. That has to be removed but before you remove that you HAVE to hoist the motor somehow like people have said above, because a motor mount is attached to that frame piece. (Not to mention, another motor mount is attached to the tranny. I believe you also have to remove the bolts on the motor/tranny mount behind and under the motor. Plan on the motor being attached to only one motor mount after all said and done.)
After that there is another smaller triangular plate near the middle of the car on the passanger side that needs to come off. After you check that your motor is securly hoisted (should already be hoisted at this point), remove the bolts that hold the tranny to the motor mount on the left side of the engine bay. Remove the 3 bolts on the motor mount behind and under the motor/tranny. Make sure everything is disconneted from tranny, reverse light switch, speed sensor, shift cables etc. Prepare to drop the tranny, use a jack or something to help you. You can't drop it alone, you need at least one other person. I say that to protect you from breaking something, people have done it on there own but I don't recommend it. Unbolt the tranny from the block and remove. There is a corner on the passenger side at the back of the engine bay that the tranny tends to get stuck on so just watch for that. You can see it from the passenger side wheel well. And like I said, there's a really good and detailed VFAQ at vfaq.com on removing the tranny but its together with the intstructions to swap a clutch. Same steps though. I think its called clutch swap or something under drivetrain. If I have said something incorrect someone correct me.
Old 10-06-2006   #10
tjg
I got the transfercase and starter off and all that is left is the tranny mounts so its coming down tomorrow morning, would be tonite but i'm taking my g/f out to the movies. Ill let you know how it goes.
Old 10-07-2006   #11
ExTREME
ExTREME's Avatar
Ahh, Where was Tachyon before? Now I might have some progress! Time to start all over. Got the TRE stage 2 yesterday in the mail.
Ironically the guy I was talking to about taking a loan out to repair my car used to own a 2g TSi. He said it was a tranny killer thats why he had gotten rid of it.
-SA
Old 10-07-2006   #12
tjg
alright i'm puting the new transmission up. I got it up but i need some help to push it on, aka little brother. Looks like i'll be taking her for a test spin late tonite. I've never drove a dsm i wonder if im going to like it.
Old 10-07-2006   #13
Hoffer00
don't worry if it all works right you will love it.
Old 10-09-2006   #14
ExTREME
ExTREME's Avatar
Not to jack this thread but, I'm having a hell of a time getting the axles out of the Transmission. Screwdriver between the tranny and the axle? Matter which side is first?
Old 10-09-2006   #15
Drivers side is bolted to the block. Once you unbolt it, it should fall right out. You will probably need something bigger than a screwdriver to pop out the passenger side axle.
Old 10-09-2006   #16
ExTREME
ExTREME's Avatar
Yeah I removed that carrier bearing.. My boot is shit on that side too..
Old 10-09-2006   #17
ExTREME
ExTREME's Avatar
Swish! Got it all disconnected. Holy post-highjacking im sorry!
-SA
Old 10-09-2006   #18
tjg
Transmission is in. I got 2 problems it stutters at 4 1/2 to 6 grand wich i think would be the fuel filter and its grinding in 5th gear and i got to hold it hard in 5th to drive it in 5th do i just need to adjust the cables or what its a remanufactured transmission from mitsubishi graveyard.
Old 10-09-2006   #19
tjg
Any suggestions would be helpful.
Old 10-09-2006   #20
tim
tim's Avatar
Just curious. How far off the floor is the clutch pedal when it is engaging?
I dont know anything about mitsubishi graveyard but I have read on Sheps site that a few hundred mile period is usually required for the trans to feel perfect. I know shep isnt mitsu graveyard but i figure that since both are rebuilds the symptoms could be similar.
Also, not really related probably but what fluid are you using?
