Old 10-07-2006   #1
95tsi
95tsi's Avatar
Drives: a pos
spark issues
The car is a '91 awd manual. The car only seems to be getting spark in the #3 and nothing else. I pulled off each plug wire and used a good spark plug and its only lighting up in the one cylinder. Tried a different coil pack, transister pack, cas, a friends ecu(which I know is good), and plug wires. I'm just about out of ideas here. All the parts which I tried were used parts so what are the chances of having them all be broken? Any help here would be great.
Old 10-08-2006   #2
95tsi
95tsi's Avatar
Drives: a pos
Re: spark issues
any help??
Old 10-08-2006   #3
Re: spark issues
So with a new plug in the wire, u see spark from the plug ONLY on cylinder number 3? Is this problem suddenly new, or have you been having symptoms before?
Old 10-08-2006   #4
95tsi
95tsi's Avatar
Drives: a pos
Re: spark issues
I just got the car for $400 (grass roots motorsports project). I dont know much of the details as to when it quit running or why. And yes, I only get spark from the #3. Nothing else sparks.
Old 10-14-2006   #5
95tsi
95tsi's Avatar
Drives: a pos
Re: spark issues
Well, after I fixed the timing with the timing belt being off... Did a compression check and there is NO compression. Guess its time for a new motor.
Old 10-14-2006   #6
Re: spark issues
If the cams were out of timing bad enough, the valves could be bent.
Old 10-15-2006   #7
95tsi
95tsi's Avatar
Drives: a pos
Re: spark issues
I'm in the process of swaping motors. Should hopfully have it running by the end of today. If all goes well.
