Old 10-08-2006   #1
Can't get into Gear
1992 tsi awd 5 spd 6/4
I can't get my car into 5th gear. The tranny will physically go into fifth, but with a lot of effort. When using the shift lever, it won't go in. I just put in a short throw shifter, symbroski bushings, shifter cable bearings, shep stage 3. I also adjusted the shifter cables tonight in hopes of helping the situation. But the cables were never changed from before the car was modded, so why now would I have difficulty?
Old 10-08-2006   #2
Re: Can't get into Gear
Remove the short-throw and see if it helps.
Old 10-08-2006   #3
the botton half im pretty sure is the same, the shaft height is different.
Old 10-08-2006   #4
Does it go into reverse fine?
Old 10-08-2006   #5
It's difficult to get into reverse as well, but I have been able to put it in reverse using the shift lever. I should add that I used this short shifter on my previous car with no problems.
Old 10-08-2006   #6
I can get into 1/2 and 3/4 with out problems.
Old 10-08-2006   #7
If you JUST put in a new transmission and all that other stuff and are having this problem it sounds like the cable(s) are out of adjustment.
Old 10-08-2006   #8
gofastman
James Bond... James Bond
gofastman's Avatar
Drives: 95 Jeep
but its hard to put into 5/R when moving the levers on the tranny, too
-David C.
Old 10-08-2006   #9
Then it's time to call Shep.
Old 10-08-2006   #10
Thor06
11 Seconds to Freedom
Thor06's Avatar
Is this when the car is on or when its off? In my experience, using the levers on the tranny wasnt easy period, I bet your shift cables are off a tad.
Old 10-11-2006   #11
I cannot get the car into fifth gear at the transmission. It's not the cables, and it's not the shifter assembly. I even adjusted the cables to no avail. I called Shep racing, and Emailed John Shephard. I am incredibly pissed. I expected perfection after spending about $2000. By the time I get this all set up, there will be snow on the ground and the car will be parked. How fucking worthless.
Old 10-11-2006   #12
Don't give up man. These things happen. I had to yank my transmission an extra time once because the guy that machined the flywheel lied to my face about the numbers he had machined it to, and once the car was running, I could not disengage the clutch.
Think about JET, how many times has he had his tranny off of his car in the last year?
With that said, I would be pissed to. Get in touch with Shep, they'll make it right.
Old 10-11-2006   #13
Shane55113
Now 20% less Racist
Shane55113's Avatar
Hey Kevin, I heard you resolved the issue, what was wrong?
EDIT: BTW this is David C.
Old 10-12-2006   #14
I got en email from John saying, "Is there a washer under your reverse light switch?" And of course, there wasn't! That fact it was sitting about .125" in too deep kept 5th gear from engaging. I made a new crush washer quick and problem solved! And she shifts great
Old 10-12-2006   #15
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Good to here. I want to see how the new car goes.
Old 10-12-2006   #16
Wow thats good it wasnt anything major!
Old 10-13-2006   #17
94AWDTSi
Can I test drive? haha
94AWDTSi is offline   Reply With Quote
Old 10-13-2006   #18
Good news! Its always nice when you have what seems to be a major problem then it turns out its just a simple fix
Old 10-13-2006   #19
I am SO relieved it was just something so small and stupid. I'm very happy with the tranny, I love actually being able to downshift and shift as if it was a normal car (haha!). I've been babying it for about 250 miles now, no hard shifts, just nice slow granny shifts with pauses halfway through the throw. ***Another note***: I also installed a act 2600 w/ spring 6puck. This clutch feels awesome. Not too stiff pedal, slips really nice (a tiny tiny bit of chatter felt in the pedal). I was expected much harsher engagement, but I wish I would have gotten a sprung 6 puck sooner!
Old 10-14-2006   #20
WRXbabe09
WRXbabe09's Avatar
Send a message via AIM to WRXbabe09
Well im glad you are happy! When are you going to beat on her and when do I get a ride???
WRXbabe09 is offline   Reply With Quote
