Old 01-26-2004   #1
ACRucrazy
90-94 Eclipse*
12V|white |+ |ignition harness |
| STARTER|black/yellow |+ |ignition harness |
| IGNITION|black/white |+ |ignition harness |
| ACCESSORY|blue/black |+ |ignition harness |
| POWER LOCK|brown/blue |- |relays right of column |
| POWER UNLOCK|brown/white |- |relays right of column |
| PARKING LIGHTS +|green/white | |above hood release |
| PARKING LIGHTS -|blue/white or gray | |steering column |
| HEADLIGHTS|red |- |steering column |
| DOOR TRIGGER|green/red |- |above hood release |
| DOME SUPERVISION|use door trigger | | |
| TRUNK/HATCH PIN|common with doors | | |
| TACHOMETER|white | |instrument cluster *1 |
| BRAKE WIRE|green |+ |brake pedal switch |
| HORN TRIGGER|grn/blk and grn/wht |-/+|steering column *2 |
| WIPERS| | | |
| LF WINDOW UP/DN|red - green |A |in drivers door |
| RF WINDOW UP/DN|red/blu - blk/blu |A |in drivers door or dkp |
Notes:
*1 Also found at a connector above the hood release. *2 Steering column wire is neg. on green/black. The other side of the horn rests at ignition on green/white. Find green/white at fuse box, fuse number 10, 10 amp. Use two relays, one to throw pos. to green/white and one to throw neg. to green/black at steering column.
Slow stuff
Old 01-26-2004   #2
ACRucrazy
ITEM | WIRE COLOR |POL| WIRE LOCATION |
| STARTER|black/red |+ |ignition harness |
| POWER LOCK|red/blue |- |*1 |
| POWER UNLOCK|brown/red |- |*1 |
| LOCK MOTOR|blue/black | |drivers door harness |
| UNLOCK MOTOR|blue/red | |drivers door harness |
| DISARM DEFEAT|blue/red | |passengers door harness |
| PARKING LIGHTS +|green/white | |in drivers kick |
| PARKING LIGHTS -|green/white 22 awg| |steering column *2 |
| DOOR TRIGGER|red/green |- |in drivers kick *3 |
| DOME SUPERVISION|*4 |- |*4 |
| TRUNK/HATCH PIN|red/green |- |driver kick panel *3 |
| HOOD PIN|blue/black |- |fuse box |
| FCTRY ALARM ARM|arms with lock | | |
|FCTRY ALRM DISARM|disarms with unlock | | |
| DISARM NO UNLOCK|green/white |- |drivers door harness |
| TACHOMETER|white | |instument cluster or PCM *5 |
| SPEED SENSE|yellow/white | |data link connector *6 |
| BRAKE WIRE|green/white |+ |brake switch |
| HORN TRIGGER|green/black |- |steering column |
| WIPERS|blu/org(L),blu/blk(H|+ |steering column |
| LF WINDOW UP/DN|grn/red - grn/black |A |in drivers door |
| RF WINDOW UP/DN|brn/yel - grn/yellow|A |in drivers door or dkp |
Notes:
*1 Located behind the glove box in a harness. To unlock only the drivers door on models with keyless entry. Use brown/blue negative(-) trigger at the relays behind the radio. *2 Found in a gray 20-pin connector. *3 To avoid the dome light delay use red/white(-) at the door open indicator at the instrument cluster. The red/white will also catch the rear hatch. *4 Use the red/green door trigger wire for dome light supervision. *5 The PCM is located on the drivers side of the engine compartment or behind the center of the dash depending on motor. *6 The data link connector is under the driver side dash.
Slow stuff
Old 01-26-2004   #3
ACRucrazy
12V|white/red |+ |ignition harness |
| IGNITION|dk. green |+ |ignition harness |
| ACCESSORY|blue/red |+ |ignition harness |
| SECOND ACCESSORY|blue/black |+ |ignition harness |
| POWER LOCK|lt. green/black *2 |- |drivers kick panel *1 |
| POWER UNLOCK|orange *2 |- |drivers kick panel *1 |
| LOCK MOTOR|lt. green | |drivers kick panel *1 |
| UNLOCK MOTOR|dk. green/red | |drivers kick panel *1 |
| DISARM DEFEAT|blue/black | |passenger kick panel or *9 |
| PARKING LIGHTS +|grn/wht or pnk/blk | |low in drivers kick |
| HEADLIGHTS|orange |- |headlight relay under hood |
| DOOR TRIGGER|green/yellow |- |fuse box *8 |
| DOME SUPERVISION|green/orange |- |fuse box *3 |
| TRUNK/HATCH PIN|red |- |drivers kick panel *7 |
|TRNK/HTCH RELEASE|green/white |5wi|drivers kick panel *7 |
| DISARM NO UNLOCK|*6 | | |
| TACHOMETER|*4 | |*4 |
| SPEED SENSE|white/blue | |center console *5 |
| BRAKE WIRE|green/orange |+ |brake pedal switch |
| HORN TRIGGER|lt. green/black |- |steering column |
| WIPERS|blu/org & blu/yel |+ |wiper motor |
| LF WINDOW UP/DN|red/blk - grn/blk |A |drivers window switch |
| RF WINDOW UP/DN|red/wht - green |A |drivers kick panel *1 |
| SUN RF OPN/CLOSE|not recommended | | |
| RADIO 12V|orange/black |+ |radio |
| RADIO SWITCH|white/black |+ |radio |
| RADIO ILLUMINATE|green/white |+ |radio |
| LF SPEAKER|wht/blu - blk/blu | |radio |
| RF SPEAKER|wht/red - blk/red | |radio |
| LR SPEAKER|yel/blu - gry/blu | |radio |
| RR SPEAKER|yel/red - gry/red | |radio |
Notes:
NOTE: This vehicle is equipped with an immobilizer. Use DEI part number 555U to bypass during remote start operation. *1 Located in a black 32 pin plug. *2 These are the door key cylinder wires. Meter the wires while turning the key in the drivers door. Unlock requires a double pulse. On vehicles without the factory alarm use purple for lock and lt. green/red for unlock, these are the door lock switch wires. *3 In the plug on the upper right side of the fuse box under the driver side dash. *4 Go to the test connector inside the fusebox under the hood, it is a T shaped plug. Tach is the terminal on the top left of the T, the wire under the terminal is white or white/red. *5 Located in a large white 38 pin plug behind the radio. *6 To disarm without unlocking, use a single pulse on the unlock wire. *7 Located in a white 43 pin plug. *8 Located in a black 19 pin plug on the back of the fuse box under the driver side dash. *9 Also found in a black 20 pin plug on the front of the fuse box under the driver side dash.
Slow stuff
Old 01-26-2004   #4
ACRucrazy
12V|blue/red |+ |left of st. column |
| STARTER|black/yellow |+ |right of st. column |
| POWER LOCK|red/blue/silver *1 |- |relays above dr. kick |
| POWER UNLOCK|grn/blu or red/grn |- |relays above dr. kick |
| PARKING LIGHTS +|green/white | |below relays dr. kick |
| DOOR TRIGGER|green/blue |- |at pin switch |
| TRUNK/HATCH PIN|red/white *2 |- |ETACS/rear door jamb |
| HOOD PIN|white/green *2 |- |at switch or ETACS |
|FCTRY ALRM DISARM|brown |- |driver's kick or ETACS |
Notes:
*1 Also type F locks red/white wire in kick panel. *2 ETACS under drivers seat - access wires at rear of running board or at ETACS module
Slow stuff
Old 01-26-2004   #5
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
Wow, that looks like a directech document. Typically only those who work in the mobile electronics field can get those. Or at Best Buy. I got em too from work. None the less still very helpful to all those without our kind of access to information.
1992 Eagle Talon TSi AWD
320awhp/320lb-ft tq
12.772 @ 108.57
1992 Mitsubishi Galant VR-4
678/1000
Old 01-26-2004   #6
ACRucrazy
huh?
Slow stuff
Old 01-27-2004   #7
LightningGSX
Hellbound
DEI directtech or techsoft.
-Nulli Secundus-
Old 01-27-2004   #8
FORSFED
All too familiar
Old 01-27-2004   #9
ACRucrazy
Yea, i know what your talking about, just throwin out a lil sarcasim.
And Directech forums are actually pretty informative! Funny to read the Circuit City guys try to cut down Best Buy guys, LOL.
Slow stuff
Old 01-27-2004   #10
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
Now now, not trying to cut you guys down. I do know some of those guys do get kind of ruthless, but they are the guys that love to put 6x9's in their old TPI Camaros with 8's and tape decks with EQ's.. Oh yeah mullets too. There opinions don't matter too much. All just jealous that BB guys have more to do than us. If there were any BB guy I wanted to jab it would be your old man Kofski. He works at that shop now right? If he does tell him the mexican boy says hey.
And back to the point, with me its all friendly competition. Which you and I both know BB will always do three times the business than CC.
320awhp/320lb-ft tq
12.772 @ 108.57
678/1000
Old 01-27-2004   #11
ACRucrazy
bwahahaha
just got off the phone with him! hes enjoyin putting a Clifford matrix 3.5 in a 03 Altima as we speak!
Hehehe, he knew exactly who u were. LOL
Well, if u go to his superbowl party, ill see ya there.
Chris
Slow stuff
Old 01-27-2004   #12
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
bwahahaha
Chris
Oh yeah, I'll be there, who can say no to hi def football? Not me!!
Icky, Altima. Nasty locks and disarm in the door and all of the other ickiness that is Nissan.
320awhp/320lb-ft tq
12.772 @ 108.57
678/1000
