Old 10-11-2006   #1
tjg
Car stutters when it hits boost!
Ok i just got the transmission in my car, 96 talon awd manual, and when i drive it every single time i hit boost the car stutters and misses and the cel comes on but goes off when i let the rpm go down the plugs and wires look good, i can rev it in nuetral and it goes all the way to 7 grand without any missfire. Can anybody help me out with this?
tjg is offline   Reply With Quote
Old 10-11-2006   #2
Re: Car stutters when it hits boost!
Mas sensor plugged in?
Old 10-11-2006   #3
INTRIGUED
insert witty title here
INTRIGUED's Avatar
Drives: VW Gti
Boost leak
Old 10-11-2006   #4
Fuel cut?
Old 10-11-2006   #5
Bad plugs or wires will stutter on load only also.
Old 10-11-2006   #6
tjg
Theres no boost leak, and the MAFS is pluged in even unpluged it to see if it made a difference but it didnt checked the tps no it. I'll pick up some new ngks today to see if it will fix it.
Old 10-11-2006   #7
What are you using for plug wires?
Old 10-11-2006   #8
tjg
I think there stock plug wires or cheap replacement wires i bought the car with a trashed tranny then put one in and now it misses, stutters and backfires
Old 10-11-2006   #9
Gravy
Who's this guy?
Dumb question time!!!!
Did you check for a boost leak?(leakdown test)
Do you know your getting spark all the time?
+1 boost leak
Old 10-11-2006   #10
tjg
No boost leak i'm going to change the plugs and wires just to make sure, Why dont auto zone or advanced auto stock ngk plugs for these cars i had to order them.
Old 10-11-2006   #11
Enes
Enes's Avatar
what mods on the car? what turbo?
i had same symptom once i put the 50 trim on the car with stock cams.. resolved the issues putin in hks cams,
Old 10-11-2006   #12
Get yourself some NGK wires while you're at it.
Old 10-11-2006   #13
I would check the gap on the plugs first, and inspect them. If they are fine then go to wires. If thats not it them check the timing ect. Little easy things then hard things.
Old 10-11-2006   #14
tjg
Car is completely stock exhaust, intake everything.
Old 10-11-2006   #15
tim
tim's Avatar
Should have went to CarQuest or Bumper to Bumper, I think they are the only ones in kato that stock NGK.
Old 10-11-2006   #16
YiNYaNg
Hold Alt & press F4...LoL
YiNYaNg's Avatar
spark plug gap
+1
Originally Posted by ecoli
Some cars are so slow that even the cops can't tell they are racing.
http://www.myspace.com/kounpheng
YiNYaNg is offline   Reply With Quote
Old 10-11-2006   #17
tjg
I checked champion bumper to bumper they had ngk but not for my car just like adavanced and auto zone they dont have it for the 2.0 turbo. My plugs are supposed to be in tomorrow morning so i'll have to swap them out tomorrow afternoon.
Old 10-12-2006   #18
acidrumz
i get my ngk's from mills fleet farm. they have the colder ranges too if you like.
check your injector plugs...they might not be seating and making good contacts.
one of my injectors plug had some corrosion. it fixed my misfire.
its nice to drive a dsm with no problems.
later.
Old 10-14-2006   #19
tjg
Alright i got it fixed it was the plugs one of them anyway and they were 7s wich are 1 step colder, there suposed to have 6s in them. And the plugs i got are ngks but they have 2 prongs i never thought ngk did that crap, so i dont have to gap them.
