Old 10-18-2006   #1
Gravy
Who's this guy?
Anyone else see a problem with this?
Guy came in today, long time 302 guy big fan of v8's and hated the "Tuner" world. So, after driving his friends turbo Civic he wanted to give the whole ricer aspect a try. So he picks up a 95 Saturn SL1, SOHC and buys a T3 turbo, FMIC, and NO fuel managment(this gets better) and goes 4 stages colder on the plugs.
So, here's where the story gets really bad.
He's running NO fuel managment system on the car, but running an upgraded fuel pump, stock injectors in the stock location, the did a direct port injection with 4 aditional injectors that increases the fuel going into the car using the boost to adjust a secondary FPR. So, as the PSI raises, the amount of gas increases to counter this. Anyone else see a tuning nightmare if 1) he gets it to work and 2) it works.
Old 10-18-2006   #2
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
Re: Anyone else see a problem with this?
A friend of mine runs a 5th injector setup on his turbo escort. It doesnt have mutch tuning range but it does the trick. You pretty mutch need to run pig rich to stay on the safe side of things. We had some real fun with it on elites dyno a few years back trying to get a desent AFR.
11.35 @ 120mph
Old 10-18-2006   #3
Gravy
Who's this guy?
He's running 4 injectors on a FPR allowing no flow under idle and as he says, "Full Cycle" under 8psi of boost. I say too much of a good thing(gas) is bad. I think he'll run too rich to run, i know with Nitrous systems you run an adition injector(s) depending on the shot sometimes.
That, and it's a SOHC saturn.
Old 10-18-2006   #4
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Send a message via AIM to CVD
You lost me somewhere between Saturn and Turbo. He's already done, an AEM couldnt save that car.
Old 10-18-2006   #5
Gravy
Who's this guy?
Thx, i love it when a v8 driver tries his luck with a 4 cylinder then spends the rest of his life bitching about it because of one bad run in.
I told him to stop by next week when he's got everything running, and try looking under the hood. I'll try and challenge him to a race to get him to buy a REAL car.
Old 10-18-2006   #6
xveganxcowboyx
Wanker
xveganxcowboyx's Avatar
Drives: 95 M3
Bad run in? No, he would be bitching due to a rediculous mistake on his part. And did he miss the part about 'tuner' involving some tuning?
Old 10-18-2006   #7
Gravy
Who's this guy?
He said this was his first venture with a "Tuner". I thought i'd say something to him... but i was on the clock.
Almost as bad as the Cavalier i see stop by sometimes. HUGE FMIC and running 5 psi of boost.
Old 10-18-2006   #8
I used to be a Saturn service manager and I can tell that a SL1 is not a "tuner" car. He should be beating his friend's ass for letting him get it.
Old 10-19-2006   #9
How did he get a FPR that completely cuts off all flow at idle? He could actually do it just using a rising rate FPR on his stock rail and injectors although he could only run real low boost. You could run larger injectors by running a FPR that has an adjustable rising rate ratio(more than 1:1) and running a lower base fuel pressure.
Old 10-19-2006   #10
Gravy
Who's this guy?
He said he "Reversed the FPR so when it's idling there's little to no fuel coming out, and as the boost incerases, it alows more fuel to enter.
I sat there as his friend had a huge smile on his face. Didn't know if it was because he thought his friend was smart... or if he actually saw the look on my face as the guy was looking for a plug 4 ranges colder for the car in our NGK book.
Old 10-19-2006   #11
You must work at a Napa.
4 range colder? I make over triple the power of a stock 3s and I am 3 ranges colder.
I would probably be fine with 2 range colder plugs but 3 were available to me.
Old 10-19-2006   #12
Gravy
Who's this guy?
Pep Boys, but i don't know why he wanted 4 ranges colder, he picked up 3 ranged colder and was going to champion to get 4 ranges if he decided to race the thing or up the boost.
Heck, i bet most people on here are only one or two ranges colder then stock and all work fine. I'm running 7's in my car ATM.
Old 10-19-2006   #13
turboDSM
turboDSM's Avatar
Drives: tastefully modded BMW : )
is it black or a dark color because i saw a Saturn with a FMIC on my way back from Saint Francis junk yard on hy47.
turboDSM is offline   Reply With Quote
Old 10-20-2006   #14
Dude, this is halarious. Get pics of his 'setup' and see if he wants to meet up sometime.
Why the hell did he get a saturn to try out the import tuner scene...that's about as bas-ackwards as...running......a....fpr...backwards...oh wait, I get it.
Old 10-20-2006   #15
x-pride
x-pride's Avatar
I bet you this was the guy who had the card board ground effects cruising UNI.
Old 10-20-2006   #16
Shane55113
Now 20% less Racist
Shane55113's Avatar
i will race him, but i'll make it even and open my waste gate
Old 10-21-2006   #17
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
hahahahahahaha my god this is awesome. I miss home. Gravy buy me a ticket home please!?
Old 10-21-2006   #18
Shotgun!
Totenritt
Shotgun!'s Avatar
You are talking about the fuel setup...Why? Even if everything was worked out just right, those blocks let go at 160whp. I'm not making this up.
Old 10-23-2006   #19
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
This thread made me dumber, thanks.
Old 10-23-2006   #20
Gravy
Who's this guy?
Yeah, it's a dark green or black color and he was heading north to Cambridge for some parts, so he probably took 169//47 all the way up.
Still no word from him, told the assistant manager about it and he's keeping an eye out for it. Hope to see how long he keeps it running before it blows up.
