Old 10-18-2006   #1
munster000
Clutch adjustment question
I adjusted my clutch. I wanted the engagement point to be further away from the ground. I moved the rod out all the way and the engagement point is still close to the floor. Does this mean my clutch is bad? The clutch fluid is full. Maybe I need to bleed the clutch fluid?
Or, is it possible that I turned the rod the wrong way? I read a thread that said turn the rod towards the firewall (out) and your engagement point will come up.
munster000 is offline   Reply With Quote
