Old 11-04-2006   #1
Pimpin Dsmstyle
Br0k3N
Pimpin Dsmstyle's Avatar
dip stick!
91 talon tsi AWD turbo. Dip stick pops out. WTF is that all about? lol.
This is like the smallest problem I've ever had and I have no idea how to fix it.. help please? rawr
- Josh L.P.
Old 11-04-2006   #2
Pimpin Dsmstyle
Br0k3N
Re: dip stick!
Crank case pressure?
- Josh L.P.
Old 11-04-2006   #3
Re: dip stick!
Yes, caused by blow by. Get a new dip stick and all should be good.
Old 11-04-2006   #4
Re: dip stick!
Also check your pcv valve.
Old 11-04-2006   #5
Pimpin Dsmstyle
Br0k3N
Re: dip stick!
How does a guy go about doing that ^^ ? I'm getting check engine lights every now and then also. Could be related possibly?
- Josh L.P.
Old 11-04-2006   #6
xveganxcowboyx
Wanker
xveganxcowboyx's Avatar
Drives: 95 M3
Re: dip stick!
PCV is located on the back passenger side of the valve cover. Just unhook the hose and unscrew it. It should only allow air to pass one direction. You can blow in it, but I think you should hook a compressor up to it to really check it's functionality.
BTW a new dipstick from Brookdale is less than $13 and a PCV less than $6.
Old 11-04-2006   #7
Pimpin Dsmstyle
Br0k3N
Re: dip stick!
nice. Thanks for the info!
- Josh L.P.
Old 11-05-2006   #8
tim
tim's Avatar
Re: dip stick!
Bah, the most n00b question there is on a DSM forum. I thought you have been around for a while.
If you want to go ghetto cheap just crimp the dip stick tube.
Old 11-05-2006   #9
Pimpin Dsmstyle
Br0k3N
Re: dip stick!
I already knew what it was. Just wanted to know if there was other possabilities. I've never ran into this problem in any of my 10 dsm's I've owned. My problems are usually alot larger than this :P
20 bucks for a PCV valve and dip stick is good enough for me No need to ghetto cheap that. If you can't afford 20 dollar fix, you don't belong owning a dsm!
- Josh L.P.
Old 11-06-2006   #10
gofastman
James Bond... James Bond
gofastman's Avatar
Drives: 95 Jeep
Re: dip stick!
SleepyDSM came up with a clever fix for this.
he looped some wire through the dipstick handle and secured the wire to the tube via hose clamp
-David C.
Old 11-06-2006   #11
Re: dip stick!
Thank you, everyone needs to read this! If you aren't will to fix something the right way when it costs under $20 you don't belong owning anything other than a bus pass.
