Old 11-13-2006   #1
skyhigh350
Send a message via AIM to skyhigh350
I bet this will stump you as it does me..
Hey guys, First off I want to say hi. I'm a member over at mitshu forums, and also on Chevy truck world, fordtruck world, offroadworld, and l13. I have been into the older 350 small block stuff for a long time, but just recently I decided to tackle somethign else. I bought a 90' gsx, and a 91'gsx, in hopes of building one nice car. The 90' has a bad body, however it had a great engine ((bad wiring harness)-got fryed due to a batt short on hood) a 3 inch stainless exhaust, a apexi timer, guage pods, face blue green gauges and a gs interior. The 91' had a terrible leather interior, a blown engine, and a perfect body, sunroof and all options. I swapped engines from the 90' to the 91'. It went well and I also did a timing belt, and a few other mods. I swapped interiors, the 3 inch exhaust and all other aftermarket mods to the 91' It is one sweet car. The 91' ecu wouldnt allow the eninge to run, so I swapped in the 90' ecu.. It works well, however the car will only run for a minute at its best (let me tell you it is fast lol) then it will dy down and load up and barley rev.. It seems like once the ecu goes to take over enigine controls, it will do this. I replaced the fuel pressure regulator, the coil pack (also everything electrical dealing with spark.) The car shows a check engine light for a few seconds while it is in rough run mode. I pulled the vacume off of the egr in hopes that it would be the that, however to no avail, it didnt work.
Does anyone have any informtion regarding this trouble? I have been working on it for about a month now, and once it runs good, I am to sell it to a friend. Two things differant between the 90' and 91, is the ecu, and the TPS (throttle positions sensor)
Thanks in advance..
rob
skyhigh350 is offline   Reply With Quote
