Old 11-21-2006   #1
piss
Send a message via AIM to piss
1g hesitates at wot higher rpm
i have a 91 tsi i just picked up, its pretty good shape, only thing i notice it hesitates/ bogs a little at wot at higher rpms. it idles a little rough too but im not sure maybe thats kinda normal? it stays pretty steady at 700rpms or so its just a little shakey.
16g(little porting), dp, lines for sale PM me
piss is offline   Reply With Quote
Old 11-21-2006   #2
Re: 1g hesitates at wot higher rpm
I start with getting new plugs and wires, and then doing a boost-leak check.
Old 11-21-2006   #3
What modifications are done to the car?
Old 11-21-2006   #4
As mentioned above: plugs, wires, base timing/idle set, boost leak check, fuel filter, check front balance shaft belt(if the motor makes a buzzing noise about 3500-4000rpm) Timing belt/water pump job if you do not know when it was done, and a clutch would help also. The list could go on, welcome to dsms.
Old 11-21-2006   #5
piss
like i said i just got the car didnt have time to look it over, sure enough the plugs were shit. it runs pretty good now with some new NGKs, the plugs in there were so worn i think the gap was 2x as big as it should be, spark was probly getting blown out or somthin.
Old 11-27-2006   #6
Gravy
Who's this guy?
Go BPR7ES plugs, everyone else uses them with great results. Get some wires and try giving it hell again. See if that fixes the problem.
