Old 11-24-2006   #1
rst95eclipse
Help with Steering Options
I didn't know where to post this in the Tech Section, so I decided to post it here. I want to run a Momo steering wheel over this piece of crizzap stock wheel. I'd like it to be quick release and have three spokes like this (http://www.power-tuning.fr/en/interi...p16741561.html). I'm not aware of any packages that come with the quick release feature. With my knowledge, you have to purchase the quick release hub all by its lonesome. Here's one which I've found but I'm not certain if it will work with the wheel above (http://www.istoreparts.com/quick-rel...er-p-4626.html). I'm pretty sure it will, since it is the 6 hole setup.
My questions are:
Are all aftermarket steering options 6 hole?
Are there any Momo setups out there that come with the quick release feature?
What would be the most common steering wheel used for a 2g?
Thanks in advance for the help guys.
rst95eclipse is offline   Reply With Quote
Old 11-25-2006   #3
Re: Help with Steering Options
The six-bolt pattern is common among the better wheels like Momo, Sparco and such, not the Pep Boyz ones. I'm not sure about the quick release, although they have some new flip up one advertised in SCC lately. I have the standard adapter on mine which puts the wheel to close to me. I'm taking it off this winter and rewelding it closer to the column.
Old 11-25-2006   #4
If you do this, remember to always have a girl with you, as you will lose your stock airbag.
