Go Back   MitsuStyle > Hosted Support Forums > Brookdale Mitsubishi
Old 12-04-2006   #1
interior radio bezel
Nick, ok I'll try to explain the piece I'm looking for. It's the plastic trim piece that goes around the radio. But not the one for the cars that came with the big 2DIN sized radios, and is just a big trim piece and one huge hole in the middle. There is one out there that is made with half of it has a hole to go around just a standard DIN sized radio, and the other half of the trim piece is a cubby hole to put stuff in. Does that make sense? I had one on my laser way back in the day, and have been unsuccessful trying to find a used one. Just wondering if you happen to have something like this. I went through CAPS on my computer here, and found nothing. Maybe you got something better to use, and can find it. Thanks!
Old 12-05-2006   #2
Nick G
Nick G's Avatar
Snow Storm Champion!
Drives: 94 v10 Ram
Re: interior radio bezel
is your car 1st gen?
that is all I can find it for mb522080 $17.34 would have to order
thank you!!
Nick
LUTHER BROOKDALE MAZDA MITSUBISHI
763-503-4695
nick.galbreath@lutherauto.com
http://www.facebook.com/#!/Luther.Auto.Dealerships
http://www.Lutherauto.com
Nick G is offline   Reply With Quote
Old 12-05-2006   #3
Sorry, yes it is a 91. Do you have any sort of picture of it that I can see, to make sure it is what I'm wanting?
Old 12-05-2006   #4
Nick G
Nick G's Avatar
Drives: 94 v10 Ram
In your caps system put in the D27A hit enter
type in mb522080 in part # section hit enter
at the top of the screen you will see PNC with a arrow, click that and it should bring you right to it.
If you still have problems you can call me.
hope that helps
thank you!!
Nick
763-503-4695
Old 12-13-2006   #5
I put in 50G for vehicle name code.
D27A in model
Then go down to the pink section, type in MB522080 into the Part No Repl P/No section
Hit enter
THen click on the PNC with an arrow. Nothing happens.
Old 12-14-2006   #6
Nick G
Nick G's Avatar
Drives: 94 v10 Ram
I can fax a picture or give me a call 763-503-4695
I close at 6:00 pm
thank you!!!
Nick
763-503-4695
Old 12-14-2006   #7
I just tried calling, but you must have stepped out.
After researching a little, sounds like that part number is right. Now does this include the whole plastic trim, AND the cubby hole? If so, go ahead and order it up!
