Old 01-05-2007   #1
blageo23
AWD4G64
blageo23's Avatar
Project Fast Spyder
This winter/spring I am doing a ton of Projects/MODs. This Thread will fill you guys in on it.
The Mods:
Built 2.4L
-Eagle Rods
-Wiseco Pistons
-ARP Head Studs
-ARP Main Studs
-ACL Bearings
-Cometic Head Gasket
-6-Bolt Main Girdle
-BS Elim
-All the Mitsu Timing parts and Front Cover
SS Fuel Lines(Possibly from the tank back to the tank)
Magnus Intake Manifold
Greddy Cam Gears
AEM Wideband Controller
Coil On Plugs
Pretty JMF Heatshield
SS Turbo Feed and Return(Both coolant and oil)
And Possibly
-HKS 280 Cams
-T-bolt Clamps all around
-Ksport Coilovers
-Aluminum Radiator
-Water Injection
-AWD
Now for the projects:
Rewire the whole engine bay to make it look clean, Split up the Big harness and make small ones that will blend in, Get rid of wire im not using(Soleniods, CAS...)
Move Ugly Underhood Fuse Box To Inside. That thing is ugly and makes the underhood look nasty
Here is where im at soo far
Picked up my Pistons, Rods and ARPs yesterday
http://www.mitsustyle.com/photopost/...m/CIMG1127.JPG
The Wire MESS! All Sorted out just need to wire loom it and disconnect the unwated wires and possibly shorten up most of the wires.
Let me know what you think.
Old 01-05-2007   #2
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
Re: Project Fast Spyder
Wow looks like one hell of a project. Good luck!
pics or gtfo
Old 01-05-2007   #3
very nice you swap it like mine awd
Old 01-05-2007   #4
92EvilTalon
3.1L v6 power...
92EvilTalon's Avatar
Pit Stop Challenge Champion!
That big of a wire project will make me go crazy for a day or two. It will look very sweet and clean when you are done. Good luck.
P.s are you moving the battery to the back or is it already done?
Josh LaCroix
Old 01-05-2007   #5
blageo23
AWD4G64
blageo23's Avatar
That has already been done
Old 01-06-2007   #6
Thor06
11 Seconds to Freedom
Thor06's Avatar
Nice dude, good luck!
Old 03-13-2007   #7
blageo23
AWD4G64
blageo23's Avatar
A little update:
Went to MAP on sunday and ordered ACL race bearings and Cometic head gasket
Also this stuff came in the mail today...
Greddy Cam Gears
COP Plate
Black Prothane Motor Mounts, AEM Serial Gauge, 6AN Fuel Line And Fuel Rail Fittings
Old 03-14-2007   #8
JustROLLIN
SpunBearing
JustROLLIN's Avatar
Nice project. And to think this all started with removing a BCS restrictor in the parkinglot of Elite on the dyno day. Quite a change....
Old 03-14-2007   #9
92EvilTalon
3.1L v6 power...
Looks like you got alot of nice parts. How did that wire tuck go or are you still working on that?
Josh LaCroix
Old 03-14-2007   #10
blageo23
AWD4G64
blageo23's Avatar
HAHA I forgot about that! That seems like along time ago.
I just went out yesterday and did some more on the wiring. Its gonna be awhile before thats done. Alot more work then I thought, but managable. Next week is my spring break and I took off work as well so I will hopefully get alot done(assuming I get up and actaully work on it)
Old 04-18-2007   #11
blageo23
AWD4G64
blageo23's Avatar
UPDATE:
Most have seen the plates and here is an update with pics.
Wiring is mostly done. Im as far as I can go without the engine in the car.
Rear suspension out and gas tank out. I have the 2 front bolts for the gas tank in and working on removing the FWD tank mounting brackets but I broke my drill bit and Im too lazy to go buy another one (right now).
I have everything I need except exhaust and fluids.Here are some pics I just took.
Interior all torn apart.
As you can see I had to drill some holes for the front tank bolts(on the inner side of the seat mounts/holder thingys)
Now for the goods...
2.4l all takin apart just gotta get it machined
Rear subframe and gas tank(yah the garage is a mess get over it )
Hard to see but its a -6 fitting on the fuel sending unit to the pump.
Rear 1/4 shot with no rear parts
Under the car with no tank or rear subframe and 2 front tank bolts in place
This should be going pretty fast now all I have to do is find time to work on it. These last few days have been "top down weather" and Im getting pissed!
Let me know what you think!
Old 04-18-2007   #12
so is it pretty easy to bolt in that rear sub-frame? Or is there some fab involved?
Old 04-18-2007   #13
Lookin' good! Are you doweling the mains on the engine? This is a must if you are putting ARP mains in. It will cost a little bit more for the machining (line honing and installing dowels), but it really should be done. I lost my first rebuilt engine because the engine builder didn't do this.
Old 04-18-2007   #14
rst95eclipse
Are you finished with the wiring? And why do you have two pairs of tin snips under the car? Problems with the heat shield? Still have a bit to go, but you could pull it off before the leaves start to change color. It's only April. As for finding the time, JUST MAKE THE TIME!!
rst95eclipse is offline   Reply With Quote
Old 04-18-2007   #15
blageo23
AWD4G64
blageo23's Avatar
All you have to do to install the rear is put some bolt in(holes already there) and bolt it up.
As for the motor. Im not sure if im going to have it dowled yet. probably tho.
The wiring in mostly finished just have to wait to get the engine in to route all the wires where they need to go. The tin snips were for the fuel lines(hard lines) I had to cut them off to get them all the way out.
Im hoping to get this out and running by FOR SURE the end of May. Hopefully ALOT sooner!
Old 04-18-2007   #16
That will be sweet. AWD spyder. BTW, it looks like the back is floating.
Old 04-20-2007   #17
blageo23
AWD4G64
blageo23's Avatar
Hopefully all the parts are good. I was just thinking that I have no clue on the mechanical condition of the tranny. So hopefully it doesnt grind!
Old 04-20-2007   #18
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Looks nice. Man is it nice to have the top down in this weather... Ha ha
Amsoil Dealer
Old 04-20-2007   #19
92EvilTalon
3.1L v6 power...
Yes tease him. Might get him to work on it faster. Wow looking really slick. Are you going to tuck the wires down by the rear Motor mount or how you running them up to the top of the engine? I love to copy your work when I get my car back. I think the wiring in the engine bay is to cluttered.....
Josh LaCroix
Old 04-20-2007   #20
Looking good man! Keep going & keep taking pics!
