Old 01-07-2007   #1
munster000
trany fluid leaks
I got done replacing my axle seal and I noticed a new leak coming from the drive axle that goes from the transfer case to the rear wheels. Looks like it is coming out of both places that there is a u coupler. What is the problem there?
Thanks
munster000 is offline   Reply With Quote
Old 01-07-2007   #2
Re: trany fluid leaks
That is a recall on the 1Gs I believe. If your transfer case has never been in for that recall you might as well try and get them to replace it. Otherwise, buy a new seal and pound it in.
Old 01-07-2007   #3
munster000
okay...what is the seal called? So, I have to take those U joints apart?
Also, this is a 90 dsm...if that matters.
Old 01-07-2007   #4
If you drop the transfer case, the driveshaft slides right out. It would be the transfer case output shaft seal I believe?
