Old 01-07-2007   #1
GUY
new slave cylinder
hi, im going to be replacing my stock clutch with a act 2100lbs. in the spring sometime, and i dont have to much faith in the stock slave cylinder, my question is should i get it replaced? and if anyone knows about how much they go for new?
GUY is offline   Reply With Quote
Old 01-07-2007   #2
Re: new slave cylinder
aslong as you are doing the clutch its a good time to also replace the clutch master and slave cylinders. From Mitsu they are really expensive, but they'll be under $100 combined from Napa, Checker, Autozone, etc. Check all their websites and order from there, for some reason its a lot cheaper than ordering in the actual store (I just went through this with my Laser). Might as well do a SS clutch line to replace the stock rubber hose too. Why are you picking the ACT2100? Look at some Southbend clutches, they are a much better product IMO.
Old 01-07-2007   #3
blageo23
AWD4G64
blageo23's Avatar
I swear I paid like $125 combined from the dealer. Personally Id go with Dealer.
Old 01-07-2007   #4
Id rather have a mitsu product for a tiny bit more money. The clutch master cylinder is a tiny PITA to install, but you can do it.
Old 01-07-2007   #5
I've never had a problem with any parts store clutch slave or master. When I got a price quote for the master from Brookdale I swear it was near $150, but I will go back and see if I can find it.
Old 01-07-2007   #6
blageo23
AWD4G64
blageo23's Avatar
I have the invoice and it was $127. That was a year+ ago and for a 2G tho.
Old 01-07-2007   #7
I couldn't find the old PM's, hit up Nick and see what he quotes you.
Old 01-08-2007   #8
http://www.dsmstyle.com/forums/showthread.php?t=9049
Old 01-08-2007   #9
I've got one with less than 500 miles on it, factory Mitsu. $50 and it's yours.
Old 01-08-2007   #10
GUY
thanks for all the suggestions when spring rolls around im gunna throw a new clutch in there and yes act because their part review i've seen are pretty much amazing, and i know nothing about southbend, and i will be replacing my master and slave cylinders along with a new a/c compressor while the axels are out, i like to stay cool in the summer!
Old 01-08-2007   #11
GUY
ask me in a couple months if you still want to get rid of it, and i will most likely pick it up from you
