Old 02-21-2007   #1
FS Ball Bearing 50 trims, dsm bolt-on
For sale:
Quantity: 2
50-5051RE turbochargers.
Otherwise known as the SCM50 ball bearing turbochargers. Rated for 450+hp each.
These are E cover 50 trims with the upgraded heavy duty actuators. Good for 36psi of boost out of these turbo's. They also hold 18psi perfectly if requested.
They feature the td05 bolt-on flange with the cut housing to help promote against boost creep.
These turbo's have been inspected are in 100% working order. 8000 miles on them approximently.
These turbo's retail for $1299+ each, plus wastegates. I would like to dump them off as they need to go to make way for other items.
$700 each. $1300 for the pair.
