Old 02-22-2007   #1
joem
Drives: 1991 Talon awd auto
91 reg cab diesel
This is a 1991 Chevrolet 2500 4x2 Pick 'em Up Truck. It has the 6.2L Diesel Engine and an Automatic Transmission (4L80E). It starts runs and drives great NO SMOKE OR LEAKS and 20-25 mpg! It would make a great work truck or farm truck! It's the Scottsdale package and equipped with Tow Package, 2WD, Power Steering, Variable Wipers and an AM / FM /CD Radio w/10 disk cd changer and 10” subwoofer. The exterior is in fair condition for the year. As you can see from the pictures it has the classic Chevy problem rockers and cab corners are rusted! The interior is grey and red leather and also in good condition just needs a cleaning. It has only a vinyl floor. The wheels are steel and the tires are new in the back and about 40% tread life remaining in the front. Here is a list of the "Original Factory Equipment" that may or may not currently be part of the truck- Solar-Ray tinted glass (all windows), Chromed front bumper, composite halogen headlamps, Dual black below-eye-line exterior 9" x 6.5" mirrors w/adj heads, Intermittent windshield wiper system, Solid exterior paint, Insulation on dash panel, cowl top/sides, doors, dual integral padded armrests, 10" rearview mirror, Dual color-keyed padded cloth sunshades, heater/defogger w/side window defoggers, Dome lamp w/dual door jamb switches, Glove box w/latched door, beverage holder, Right-hand side coat hook, Under dash cup holders, Speedometer, odometer, voltmeter, fuel/engine temp/oil pressure gauges w/ telltale lights, Color-keyed door sill plate, Cigarette lighter 8600# GVWR Independent front suspension, HD chassis, Mechanical jack & wheel wrench, Power front disc/rear drum brakes, 140 amp alternator, Front 1.18" diameter stabilizer bar, Engine oil cooler, Semi-elliptic rear 2-stage suspension w/multi leaf springs, Two wheel drive, 32 gallon fuel tank, Power steering, and Double-wall steel construction 8' pickup box.
Joe
