Old 03-18-2007   #1
Talon628
Talon628's Avatar
OBD II plug problem.
97 GSX, The OBD II plug under the steering colum doesnt work. When you plug the OBD into it, it never turns on. Was Wondering if any one can gimme some ideas of what to look for or what to check.
YOU GOT MY MONEY!!
Talon628 is offline   Reply With Quote
Old 03-18-2007   #2
Re: OBD II plug problem.
So just to clarify, the car runs fine, but if you plug in and ODBII plug into the port, it will not start? Won't turn over? Please be more specific.
Old 03-18-2007   #3
Can you at least pull engine codes and whatnot with the key on?
Old 03-18-2007   #4
blageo23
AWD4G64
blageo23's Avatar
I think he is saying that the scanner never turns on. Do you have a volt meter? Pin #16 is power and Pin #4 is ground. Put a voltmeter there and see if you got power.
Old 03-18-2007   #5
Talon628
Talon628's Avatar
pin 16 and 4 sweet that helps alot, Ill check those cuz my feeling is its not getting power so yah thanks. umm ill keep yah posted.
YOU GOT MY MONEY!!
