Old 03-28-2007   #1
kennydawgg
Throttle bodies
me and a buddy are looking at building a velocity stack intake and we can build it to mate up to any throttle body. Anyone have any Idea on the best one to use?
kennydawgg is offline   Reply With Quote
Old 03-28-2007   #2
DBMajik
Re: Throttle bodies
Depends on what turbo you're running. I'd do a Q45 TB.
DBMajik is offline   Reply With Quote
Old 03-28-2007   #3
Capinoy123
Capinoy123's Avatar
Drives: A paint faded Red/pink/black 90 eclipse. Collector Plates!
Re: Throttle bodies
I'd Go with a Q45 too! Works great! and looks good
Best E.T 10.5 @ 137 on 30 psi, E-85 and street tires! (never dyno'd)
Capinoy123 is offline   Reply With Quote
Old 03-28-2007   #4
kennydawgg
Re: Throttle bodies
14b turbo, but I will probably upgrade later this summer
Old 03-28-2007   #5
Re: Throttle bodies
Do the bolts for the Q45 throttle body line up with the Stock 2g bolts? Anyone know this?
Old 03-28-2007   #6
Re: Throttle bodies
No they do not.
Old 03-28-2007   #7
Re: Throttle bodies
Which ones do? The Rustang? 1g? Holley Double pumper?
Old 03-28-2007   #8
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
Re: Throttle bodies
Sounds like 1g tb would be fine for this fella.
pics or gtfo
Old 03-28-2007   #9
Re: Throttle bodies
It would be best to cover both stock and a 90mm TB, what are you going to make the smim out of?
Old 03-28-2007   #10
kennydawgg
Re: Throttle bodies
I'm thinking aluminum but we can make it out of stainless if we want, the metal will probably be free. will the stainless be better because of less heat that will be transfered from the block?
Old 03-28-2007   #11
Re: Throttle bodies
Unless you're going big on the turbo in the future, the stock TB is more than adequate.
