Old 04-01-2007   #1
desolate
91 TSi AWD
desolate's Avatar
Drives: red 91 TSi AWD auto
FS: 1g partout + misc cheap!
Sold the car and so I have a few parts left over I need to get rid of.
1g fuel rail + 1g fpr = $5
1g throttlebody elbow = $5
2g shift knob (this is a nice upgrade from the long 1g shifter) = $15
NT Waterpipe (great upgrade for those upgrading to a big turbo, I also welded the port that flows coolant out to the throttlebody) = $10
1g crank pulley (pulled from a running turbo 1g) = $20
1g upper timing belt cover = $5
1990 ECU (pulled from running dsm) = $75
Stock 1g MAS (hacked) = $5
1990 Transistor Pack = $10
Updated (4-8-07)
Old 04-01-2007   #2
xveganxcowboyx
Wanker
xveganxcowboyx's Avatar
Drives: 95 M3
Re: FS: 1g partout + misc cheap!
I'm curious about the intake pipe. Could you post a picture?
Also, is the ecu eprom?
Old 04-01-2007   #3
desolate
91 TSi AWD
desolate's Avatar
Picture of the Buschur CAI
https://home.comcast.net/~qwert152/IMG_4073.jpg
The 1990 ECU is not Eprom.
Old 04-01-2007   #4
xveganxcowboyx
Wanker
Drives: 95 M3
Is it for a non-turbo?
Old 04-01-2007   #5
tim
tim's Avatar
How old is the battery? Do you have a part number for it?
Old 04-01-2007   #6
I'll take the Hyundai valve cover. Where are you located?
Old 04-02-2007   #7
Berda
Berda's Avatar
Send a message via AIM to Berda
I'll take the valve cover if Steve doesn't.
'91 TSi AWD Stock - 161.7 AWHP! Sold :(
'99 Honda Accord EX Coupe V-6.
Berda is offline   Reply With Quote
Old 04-02-2007   #8
tnm27
I'm the short one.
tnm27's Avatar
i'll take the intake manifold..pm sent.
tnm27 is offline   Reply With Quote
Old 04-02-2007   #9
DSM_421
I'll take shift knob
Old 04-02-2007   #10
DSM_421
Also will take the lightweight battery, and upper timing belt cover.
edit - pm sent
Old 04-03-2007   #11
desolate
91 TSi AWD
desolate's Avatar
replys sent!
Old 04-03-2007   #12
Do you have an ignitor chip for a '90?
Old 04-03-2007   #13
desolate
91 TSi AWD
desolate's Avatar
Are you talking about the transistor pack for the 90 dsm? If so I believe I do have it - $10.
Old 04-03-2007   #14
Could be, is that the little box that plugs in next to the coil pack? Cause that's what I need. I'll PM you.
Old 04-03-2007   #15
desolate
91 TSi AWD
desolate's Avatar
Also I'm adding a 1990 Tranny in good shape when it was pulled. I drove the car before the tranny came off and there were no grinds shifting. Worked great! - $120. I also have a 23 spline transfer case (I think) I'll give away free with the tranny. The transfer case needs to have the seals replaced. I don't think they will work together though.
Old 04-04-2007   #16
Justin Anderson
I'll take the transmission.
Justin Anderson is offline   Reply With Quote
Old 04-04-2007   #17
Justin Anderson
Did you sell the car without a transmission in it? Just wondering why you took a good transmission out. No offence just watching my back. I know all to well about dsm transmissions.
Old 04-04-2007   #18
Talon628
Talon628's Avatar
where do you live? I need the intake manifold,the crank pulley,and the fuel rail.so $40 right.
YOU GOT MY MONEY!!
Talon628 is offline   Reply With Quote
Old 04-04-2007   #19
desolate
91 TSi AWD
desolate's Avatar
I'm located in Oakdale. Mapquest:
6690 Upper 28th St. N
Oakdale MN 55128
I still have the intake mani, crank pulley, and fuel rail ($30)
everything is on a first come first serve basis
The tranny I am selling is a separate tranny. My car had it's own.
Old 04-04-2007   #20
desolate
91 TSi AWD
desolate's Avatar
I went to double check and yes I do have the 1990 Transistor Pack. It came off a running dsm so I know it works. - $10
Updated the list as well.
