Old 04-12-2007   #1
thom1301
Tire Wear / Mileage
I have a nearly stock (intake, recirc BOV, boost controller) '96 AWD Talon. I just checked the tires, and rears are worn down almost to the wear bars, and the fronts look almost new. This is after about 25,000 miles on BFG Traction TAs (all season) in 215/55/16. Any ideas on why this would be? The rear wear is pretty even, with just a little more wear on the outsides of the tires. I do 95% highway driving, and still only get 22-23 mpg. Any thoughts?
thom1301 is offline   Reply With Quote
Old 04-12-2007   #2
Re: Tire Wear / Mileage
Get your alignment checked and make sure your tire preasures are properly set.
Your car is probably in need of a tune-up (plugs, wires, fuel injector cleaner, etc.) and a tune.
Old 04-12-2007   #3
thom1301
Yeah, I'm thinking I need an alignment, but it's weird that the rears wore almost evenly, just much worse than the fronts.
I have new plugs, wires, fuel filter, upstream 02, but I should clean my K&N.
Old 04-12-2007   #4
Tire rotations are a good thing.
Old 04-12-2007   #5
bluntedelvis
Click,Click,BOOM!!!
bluntedelvis's Avatar
Every other oil change I rotate mine.
Old 04-12-2007   #6
Normally the fronts wear faster than the rears on a DSM. It is always a good idea to rotate them about every 1/4 of tread life. Every 10k or so on normal tires, less for high performance tires.
Old 04-12-2007   #7
thom1301
That's what I thought too. Any reason why the rears would wear twice as fast? Anything to do with the T-case or something? Or just alignment?
Thanks for suggestions everyone.
Old 04-12-2007   #8
polishmafia
Smells like cat poop
polishmafia's Avatar
check alignment, adjust camber if needed, rotate and check pressure. tires are just too friggen expensive not to do it.
Old 04-12-2007   #9
thom1301
Can any alignment shop perform a 4-wheel alignment of these cars, or do they need to have special equipment/be in the know?
Travis
Old 04-12-2007   #10
tim
tim's Avatar
If you have even tire wear across the face of the tire and the car isnt pulling there is no reason you should have your alignment checked. It would be a waste of money.
How often do you do your rotations? I recommend every 6-8k for all season tires.
Old 06-04-2007   #11
thom1301
Just in case anyone has the same problem, my rear had way too much toe in. Both sides were out of spec, and the side that was more out of spec, was the side where the tire was more worn out. FYI
