Old 04-27-2007   #1
blageo23
AWD4G64
blageo23's Avatar
Rear End And Tcase Fluid
What do all you guys run or recommend for the rear end and tcase?
Thanks.
Old 04-27-2007   #2
Re: Rear End And Tcase Fluid
Redline 75W90
Old 04-27-2007   #3
Redline 75W90
A very good choice, but Mobil 1 75W-90 can withstand more shock. I am a huge fan of Redline fluids, but this one product of theirs is beat out by Mobil 1. Either way, both are great products.
Old 04-27-2007   #4
Link to data to back up this claim?
I usually use the shockproof liteweight or heavyweight in high hp/high load applications.
Old 04-27-2007   #5
Redline Heavyduty shockproof in the rear, and the MTL / MT90 mix in the Tcase is what I run.
Old 04-28-2007   #6
Its somewhere in the "oil journals" on the S2ki forum, but when I get a chance (if I remember), I'll dig for it.
Old 04-28-2007   #7
Awesome, I love to read up on stuff like that.
Old 04-28-2007   #8
So far all I've found are viscosity ratings at various temps and the pour points, but I'll continue the search!
In the meantime, there are some great articles here:
http://www.s2ki.com/forums/index.php?showtopic=195574
I am not sure if you need to be registered to read the threads, but if you are the info contained within is definitely worth the few minutes it takes to sign up. There is info on engine oils, tranny fluids, and gear lubes that pertains to all cars, not just S2000's.
You summer-only and race-only guys should really look into a product called LE-607 (read articles at link above to learn why), all the testing shows its a better choice than the Redline Shockproof stuff for both the street and track. Redline techs recommend against using the Shockproof in street cars due to odd viscosity behavior at low(er) temps.
