Old 04-29-2007   #1
justinhill
BetHiLow Streak Un-Censored Champion! League Bowling Champion! Snowboard Champion!
Drives: 98 gst eclipse
Send a message via AIM to justinhill
trouble aahhhhh
i have a probley it seems like a miss fire i get going and when i hit 4000 rpms it starts to hesitate so i put new wires and new plugs and the recoil was replace i was starting to think could it be a clog in the fuel line or could it be a bad fuel filter? its a 95 gst with a 14b turbo..
justinhill is offline   Reply With Quote
Old 04-29-2007   #2
dumb_ricer
Hates Everything
Drives: Neon
Re: trouble aahhhhh
Does it have an AFC?
420A > LS1 > All Else
I > All else
Old 04-29-2007   #3
justinhill
Re: trouble aahhhhh
i think so.
Old 04-29-2007   #4
dumb_ricer
Hates Everything
Drives: Neon
Re: trouble aahhhhh
Do you have something that sits in your car that says Apex'i on it? Its about 2.5inches by 5 inches, maybe a half inch thick, and it has buttons on it.
If you are running a 14B, I would recommend getting one, as it could very well be your problem.
I > All else
Old 04-29-2007   #5
x-pride
x-pride's Avatar
Re: trouble aahhhhh
Sounds like boost leak?
Old 04-29-2007   #6
justinhill
Re: trouble aahhhhh
no i dont have one of them yet but i dk i pretty sure its not a boost leak ... but could be ill go run some test and see.. thanks
Old 04-29-2007   #7
Re: trouble aahhhhh
Yea, run a boost leak test, see how much pressure the intake system can hold.
Old 04-30-2007   #8
justinhill
Re: trouble aahhhhh
yeah i was also told to turn up the boost im pushing 10 psi right now then i was told to turn it up to 15 and run it for a bit but thats what a guy from mitsubishi told me to try doing.
Old 04-30-2007   #9
x-pride
x-pride's Avatar
Re: trouble aahhhhh
Who put the 14b in for you? What waste gate are you running? Let us know about you car and mods it have? Did you do a boost leak test yet!
Old 04-30-2007   #10
justinhill
Re: trouble aahhhhh
i bought that 95 gst eclipse that was on here from charlie it has just the 14b turbo and a hks intake. thats about it.i havent had it check for a boost leak i been to busy with work and stuff but hofly friday i can run some test..
