Old 05-20-2007   #1
kennydawgg
afpr help
ok put in a new adjustable fpr and im having some issues. when the key is on and car is off the gauge reads 0. when running it says 0, I got the gauge to move a bit when I revved it. but I havent got it to move again.
if the vac line has a leak would this cause the problem? could my fpr be bad? what should it read if the fuel pump is on and the motor is not?
thanks
kennydawgg is offline   Reply With Quote
Old 05-20-2007   #2
Re: afpr help
if it's on, and the motor is off, it should read whatever the FPR is. Did you try to raise/lower the fuel pressure? You could have a bad gauge. What kind of setup is it?
-A. Swift
Old 05-22-2007   #3
kennydawgg
Re: afpr help
I tried adjustng the screw and nothing, its just a cheap ebay one
Old 05-22-2007   #4
Re: afpr help
The gauge is broke. The car wouldn't run with 0 psi of fuel pressure. Get a different gauge.
