Old 05-21-2007   #1
Onefast99gsx
Question Shitty ordering luck or what? Aluglide vs. Duraglide
Hey guys-
Well since I found out my crank had the mains cut AND the rod journals .010", I had to order new rod bearings because I originally got STD. The original standard bearings I got where Aluglide.
I was going to put the pistons in tonight and I open the box up and take 1 bearing out and I was like what the heck. I look at the box and it says Duraglide 780. The Aluglides were shiny aluminum. These new ones have a gray coating on them like the color of lottery scratch off's.
All my research went into the Aluglides and I know nothing about these Duraglides. Should I not use them and tell ExtremePSI that I want Aluglide or what?
Also...If it's ok to use them, my machine shop always recommends to clean any burrs up with 800 grit sand paper and rinse off with brake cleaner. Would I damage these by doing that?
Thanks for any info.
