Old 05-23-2007   #1
DBMajik
Aem Ems
I just installed AEM EMS and I'm looking for a basemap so I can drive my car to DB to have it tuned. Just seeing if anyone can help; because I'd really hate having to get a flat bed to tow it from Minneapolis to Rogers.
My relevant mods are: 2.3l, 750cc FICs, stock cams, stock intake mani, dnp exhaust mani, open downpipe. GM AIT, 5 bar AEM MAP, GM BC Solenoid, AEM UEGO connected to stock o2 wire.
DBMajik is offline   Reply With Quote
Old 05-23-2007   #2
Re: Aem Ems
What size turbo?
Old 05-23-2007   #3
Re: Aem Ems
Just have Shane send you a basemap.
Old 05-23-2007   #4
Re: Aem Ems
a 2.3L using stock 2.0 cams huh. i hope you arent expecting a lot of power.
Old 05-23-2007   #5
Re: Aem Ems
There's a couple in the calibrations file that should get you up there. Just don't get into boost. Worst case you pick the 450cc one then open the fuel map with the key on but not started, right click anywhere on the map and the bottom option is "change fuel pressure/injectors". Put 450cc in the top box, 750cc in teh bottom and you'll be good to go.
Old 05-23-2007   #6
DBMajik
Re: Aem Ems
What size turbo?
That's not relevant unless someone offers a boost comp map. You will have to find out on the freeway.
I have the basemaps that come with AEM. I did what Steve said and scaled the injectors to 750ccs on a basemap, but the car won't idle. I removed the FAIV and Stepper motor while installing some new parts. Maybe that's why?
It's unbelievable how many people tell me this, even after building the motor myself.
This tune is to get the car running to get me to work to make money for everything else I need to complete my build.
Old 05-23-2007   #7
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: Aem Ems
Since it doesnt matter on the "base tune" to get you to DB, bring up the fuel map and select the first 3-4 rows up (vac-boost) and 4-5 rows to the right (RPM) up to say, 2000rpms and start tapping the "+" key to raise the fuel until it idles. This will get you by to DB.
Make sure you select the "MAP" calibration. Go into the sensor menu and make sure the AEM 5 bar is selected and do the same thing with the IAT sensor.
Hope this helps a little.
Originally Posted by shoutbox
Old 05-23-2007   #8
Re: Aem Ems
Did you ask shane to send you a basemap, since you are getting it tuned up there?
Old 05-24-2007   #9
DBMajik
Re: Aem Ems
Thanks I'll see how that goes.
I'm speaking with him in PMs about it right now. I like fiddling with stuff myself, that's the reason why I'm asking others for suggestions.
Old 05-24-2007   #10
Re: Aem Ems
It doesn't need to idle to drive it. A car that actually idles is for pansies.
Old 05-25-2007   #11
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
Re: Aem Ems
Unless it doesn't re-start well, then you can get in the way.
Old 05-27-2007   #12
DBMajik
Re: Aem Ems
In that case you must have one pansy ass car.
Old 05-27-2007   #13
Re: Aem Ems
lol, call steve out. I bet you will regret it I can say my car idles, and sounds rather mean. I love it!
-A. Swift
Old 05-27-2007   #14
Re: Aem Ems
Yeah, I can't get my car to idle decent under 1100 rpm with the big ass cams I have. Steve probably has one of the quickest cars on the site once he gets it to the track!
Old 05-27-2007   #15
Re: Aem Ems
Mine idles nice and steady at 1600 rpm, after warming it up by pedal for a few minutes. Anything less than 1500 rpm shakes my fillings out with those poly engine mounts.
Old 05-28-2007   #16
DBMajik
Re: Aem Ems
-A. Swift
Ha, I still need a good $10,000 in parts to compete with anyone over 300hp.
I will love it when I have that problem.
