Old 05-24-2007   #1
Highly Modified 1995 GSX for Sale $6500
White 1995 GSX 5spd -
http://www.scottbarton.net/Brian/Eclipse%20Test%20Page/
I'll start with the bad:
-Spun bearing in the motor
-rust holes in the front strut towers that have been bondod but needs to be finished (sanded/painted)
-Body kit/entire car could use paint
-Stereo is currently out of the car except for the door speakers
Onto the good:
Performance:
6 Bolt Motor (had 3000 miles on the rebuild) (motor paid $4500)
Eagle Rods ($400)http://www.dsmtuners.com/parts/produ...roducts_id=551
Wiseco Pistons ($499)http://www.dsmtuners.com/parts/produ...roducts_id=582
Commetic Head Gasket Copper Sprayed
K&N Air Filter w/2G Adapter ($45)
Forced Performance 4" Intake Pipe ($69)http://store.forcedperformance.net/m...ode=DSM-Intake
Turbonetics "T3" Cast Exhaust Manifold ($475)http://www.dsmtuners.com/parts/produ...roducts_id=169
HRC Head to Manifold Spacer Plate ($100) http://www.hahnracecraft.com/hahn/parts/install.htm
Tial 38MM External Waste Gate ($230) http://store.straightlinespecialties...roducts_id=278
PTE T04S GT3575 Turbo with .63A/R (has 300 miles)
Braided SS Oil Lines with A/N Fittings
Braided Coolant Lines with A/N Fittings
Braided SS Clutch Lines
Braided SS Brake Lines
Custom 3" 02 Housing by Jet Customs ($125)
Custom 3" Downpipe by Jet Customs ($300)
Custom 1.5" Dump Tube by Jet Customs ($25)
Custom 2.5" Short Route I/C Piping by Elite Autosport
Hose Technic Couplers
Hose Technic Reducers
T-Bolt Clamps ($8) each
Apexi 3" N1 Catback Exhaust ($629)http://www.dsmtuners.com/parts/produ...roducts_id=194
Apexi Skyline GTR FMIC ($700) Is what I paid shane for I/C and FMIC
http://www.dsmtuners.com/parts/produ...roducts_id=274
2x10" Slim Fans (1000cfm each) ($80) for the set off Ebay is what I paid
Blitz Super Suquential BOV ($255)http://www.extremepsi.com/store/cust...me.php?cat=361
1G DSM Throttle Body ($35) at local junk yard I'm sure
Magnus 1G Sheet Metal Intake Manifold ($745)http://store.forcedperformance.net/m...ode=DSM-Intake
Fuel Injector Clinic 850 Injectors ($279)http://www.extremepsi.com/store/cust...me.php?cat=429
ARP Head Studs
HKS 272/272 Cams ($550)http://www.dsmtuners.com/parts/produ...roducts_id=536
Complete 1G Head
1MM Oversized Valves
Fidenza Cam Gears ($180)http://www.dsmtuners.com/parts/produ...roducts_id=486
Crower Springs & Retainers ($250)http://www.dsmtuners.com/parts/produ...roducts_id=545
170 Degree Thermostat
Fluidyne Radiator ($379)http://www.extremepsi.com/store/cust...cat=373&page=1
Taylor 10MM Spark Plug Wires
NGK BPR7ES Spark Plugs
Walboro 255hp Fuel Pump-Rewired ($165)http://store.forcedperformance.net/m..._Code=DSM-Fuel
Prothane Motor Mounts ($95)http://www.boneheadperformance.com/dsm/dsmengine.htm
SouthBend Custom Clutch (300 miles) ($300)http://www.dsmtuners.com/parts/produ...roducts_id=888
SouthBend Custom Flywheel (300 miles) (must be $455) cause the total for flywheel clutch was $855.
Shep Racing Stage 4 Tranny ($2300) with 4 gear Spider Diff($275) (300 miles)http://www.sheptrans.com/details.php?sid=1
B&M Short Throw Shifter ($175)http://www.dsmtuners.com/parts/produ...roducts_id=262
Extreme Manual Boost Controller ($100) (I had there original)http://www.extrememotorsports.com/ca...r-p-32863.html
Oil Catch Can w/Breather
Sealed Coolant Over Flow Tank
Auto Meter Grey 3 Gauge A Pillar Pod
Auto Meter Phantom EGT Gauge with Racing Probe
Auto Meter Phantom 30/30 Boost Gauge
Auto Meter Phantom Oil Pressure Gauge
DEI Thermal Wrapped Downpipe
DEI Thermal Wrapped I/C Piping
1995 Socketed Eprom ECU
DSMLINK Version 2 ($565)http://www.dsmlink.com/ordering.html
IBM Think Pad Laptop
Rear Strut Tower Bar
Front & Rear KYB AGX Adjustable Shocks ($350)http://www.dsmtuners.com/parts/produ...roducts_id=396
Front & Rear Ground Control Coilovers ($399)http://www.dsmtuners.com/parts/produ...roducts_id=343
Rear Power Slot Rotors
Hawk Brake Pads
Yellow Top Battery - Type 51R ($200) Not made anymore, but new last year
18x8 White Konnig Toxxin's
Parelli Tires (New rubber 300 miles)
Removed A/C System
New Alternator (300 miles)
I have a GM MAFT Trans but not installed (at LSE )
Interior
6 Point Mild Steel Cage ($750) $150 for cage and $600 install
Sparco Color 2 Steering Wheel ($215)
Sparco Steering Wheel Adaptor Hub ($50)
Sparco Torino Racing Seats ($599)each http://www.sparcousa.com/pseats_street.asp?id=195
Sparco Fully Adjustable Seat Mounts ($110) originally I paid $150 for each seat mount, which included the sliders, etc
Sparco Seat Slider ($59ea)http://www.sparcousa.com/pseats_acc.asp?id=156
Sparco Pull Up Cam-Lock Lap Belts ($299 for each complete harness system)http://www.sparcousa.com/pharness_comp.asp?id=579
Sparco 48" Shoulder Harness's
Sparco Sub Belt - Dual
Momo Shift Knob
White Faced Indeglo Dash Gauges w/dimmer
White Faced Indeglo A/C Gauge Overlay
Custom Three Tone Interior
Custom Vinyl Tweeter Mounts
Custom Vinyl Shift Boot
Custom Vinyl Arm Rest
Custom Vinyl Amp Rack
Custom Vinyl Sub Box
Exterior:
Altezza Euro Generation 1 Tail Lights
Hyper White Headlights
Spoilers Etc – Ninja Front Bumper
Spoilers Etc – Ninja Rear Bumper
Spoilers Etc – Blitz Low Side Skirts
99 Style Reverse Lights
Painted Center Tail Light Section
Removed Side Markers
Removed Fog Lights
White Mesh for Side Skirts
White Mesh for Rear Bumper
Misc Mods:
Polished Fuel Rail
Polished Thermostat Housing
Polished Sheet Metal Intake Manifold
Polished 4” Intake Pipe
Polished Oil Cap
Polished Radiator Cap
Polished BOV
Polished & Shaved Valve Cover
Polished Throttle Cable Mounts
Polished I/C Clamps
Polished MBC Mount
Polished Coil Pack Mount
IO Port Racing Camcorder Mount
Achievements/Awards:
Dsmstyle.com Car of the Month
Xratedcc.com Car of the Month
2002 Featured on AARRF Website
DSMTUNERS – 2002 Voted Best 95-96 DSM
DSMTUNERS – 2002 Voted 4th place Best Overall DSM
Dec 2004 1st Highest HP 2G DSM Stock Block - Elite Autosport
Dec 2004 3rd Highest HP 2G DSM in MN - Elite Autosport
Dec 2004 9th Highest HP DSM Overall in MN - Elite Autosport
2001 VolkSport – Best Import Drag Car
2002 VolkSport – Best Import Drag Car
2003 All Mitsubishi Cook out – 2nd place Best 2G DSM
2003 Mach 1 Car Audio – 2nd place Best Import
4 Time 1st place Finisher at Rock Falls Raceway
Autovations 2004 - Runner up Best Mitsubishi
143.2db’s at Audio King DB Drags
2005 Featured on Elite Autosports Website as a Customer Car
2006 Featured/sponored by LSE-Performance
Stats: All done on old PTE TO4S 3561 .63A/R Turbo
Best Pump Gas Dyno’d whp: 403.2whp@22psi, 92 oct Stock Block (Elite)
Best Race Gas Dyno’d whp: 456.7whp@25psi, C16 Stock Block (Elite)
Best Pump Gas LSE AWD (379whp@25psi) - with bad motor
Best Race GAS LSE AWD (440whp@30psi) - with bad motor
Best 1/4 Mile on Pump Gas: 11.715@114.08mph - 25psi, 93 oct
Previous Best 1/4 Mile on Pump Gas: 11.904@115.91mph - 22psi, 93 oct
I have all kinds of video's of this car, and I have all kinds of pictures the link above hasn't been updated in a long time so mod list might vary. I think thats everything anyquestions just message me or post.
