Old 05-28-2007   #1
96 Gsx Awd
96 Gsx Awd's Avatar
Send a message via AIM to 96 Gsx Awd
I give it gas, it boggs down
Ok so i new i needed a new alternator so i drove out to my buddys house and installed a new alternator. When i drove out there i had no problem at all. After done installing the alternator my battery light went off. Everything seemed to be ok. Well when i started taking off my car would bogg down like it was not getting gas. NOw when i start it up it will bogg down and will not pick up rpms. Then it kinda sounds like its farting and a little black smoke will come out. I tested my compression and checked my turbo to make sure its not locked up, and i got perfect compression and no oil in turbo. I also checked my spark plugs and wires. All good. So i have no clue on what is going on now. I just had a 6bolt installed and really have not had to many major issues untill now. Any clue as to what is going on would be really helpfull. Thanks all. ~96 gsx awd~
Finally tuned and fully built, Takes a lot of time,patience and money!!
96 Gsx Awd is offline   Reply With Quote
Old 05-28-2007   #2
Re: I give it gas, it boggs down
Make sure the plug wires are on the right cylinders and that an intercooler pipe isn't off or the MAS is unplugged.
Old 05-29-2007   #3
96 Gsx Awd
96 Gsx Awd's Avatar
Ok i will check to make sure mas is not un-done thanks.
Old 05-29-2007   #4
96 Gsx Awd
96 Gsx Awd's Avatar
ANybody else know what it could be??? THanks all
Old 05-29-2007   #5
96 Gsx Awd
96 Gsx Awd's Avatar
i put a data logger on it and it gave me a mas error and o2 error. I just had a brand new 02 sensor put in. Should i try replacing the mas with another just to see it if it fixes it? any other things i should try????
Old 05-29-2007   #6
MacGSX
Drive By Shooting Champion!
I had this same problem, but I forgot to plug m mas back in its probably somthing minor....Boost leak check?
PTE 50trim, PTE 880's, Wally 255 fp, Aeromotive AFPR, ACT 2600 w/flywheel, Evo3 exhaust mani, Evo3 O2 housing, RRE 3'' DP, RRE high flow Cat, APEX N1 catback, Greddy FMIC, ExtPSI Intake, Greddy type S BOV, DSMLINK, Greddy E-01 BC
MacGSX is offline   Reply With Quote
