Old 06-24-2007   #1
gsx&gsxr
boosting on stock guts
what is the max boost that is safe to run if i am still using the stock internals
gsx&gsxr is offline   Reply With Quote
Old 06-24-2007   #2
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
Re: boosting on stock guts
68psi. BOOST AWAY!!!!!
pics or gtfo
Old 06-24-2007   #3
This is probably the 2nd most asked question, right after 'how do I hook up a mbc?'
No one's going to be able to answer this but you and your datalogger.
To start, how about some details about the car: what turbo? what other mods? what type of fuel management? what type of fuel?
This may sound hypocritical, but otherwise it's like asking a reeeeaaaly slutty cheerleader who's drunk how many...ahh, nevermind, just give us more info!
Old 06-24-2007   #4
Do some more research please.
But we will def. need more info to answer your question.
Stock internals rated to 400hp, i would say 350hp on our rollers to be safe, that is what i am shooting for with a 155k motor and shitty/uneven compression.
Old 06-24-2007   #5
1g or 2g? I ran 26-27 psi on my small rod '99 stock shortblock. But I ran a conservative tune. NO KNOCK, detonation will break parts. I have read/heard of 400-500hp on a big rod 1g, but I have not seen it personally. The tune is the key.
Old 06-25-2007   #6
iceminion
iceminion's Avatar
Map has a stock 6-bolt engine running 450ish WHP
building a 3000GT AWD Turbo.
Old 06-25-2007   #7
Nash ran over 500 whp on his 1g big rod/2g piston combo and 40 psi.
Old 06-25-2007   #8
bluntedelvis
Click,Click,BOOM!!!
bluntedelvis's Avatar
I'd say 15-20 psi would be safe for ya.
Old 06-25-2007   #9
HiImBrian
HiImBrian's Avatar
Well yea 15-20 is safe, but it's definitely not the "max safe" like the first post asked. Shit 5psi is even safer if your looking to be nice to the motor. Again, this is a tough question considering the shape of the motor and the modifications that are on it.
pics or gtfo
Old 06-25-2007   #10
You should be good to the high 20's with just some head studs.
Old 06-27-2007   #11
gsx&gsxr
my mods are
Turbonetics 60-1 T3/T4
Tial 38mm waste gate
HKS SSQ BOV
Turbosmart MBC
XS POWER FMIC, 2.5in piping aluminum.
Walbro 255 fuel pump
AFPR 1000,
PTE 680cc injectors,
3"in exhaust,
XS POWER tubular header,
MAF-T with 3inch MAS,
3inch intake piping (plastic),K&N cone filter
Samco sport radiator hoses,new thermastat,slim cooling fans.
and a brand new wiring harness
its got like 1.28k on the motor
Old 06-27-2007   #12
Oh yes he did.
Old 06-27-2007   #13
With that list I am sure you already have head studs in? If so you are good to go.
Old 06-28-2007   #14
I didn't see fuel management anywhere in your list. What are you using? An AFC will severely limit the amount of boost you can run on pump. DSMLink or AEM should let your run 22-24psi on pump with that turbo, but just like I stand behind my original answer:
No one can answer this except you and your datalogger.
