Old 06-30-2007   #1
green hornet
installing a 1g 4g63 in a 2g?
ok i am new to the 4g63 so bear with me here! is a first 1g 4g63 a direct swap into a 2g car?
if not what is needed to be done?
Old 06-30-2007   #2
johnson
johnson's Avatar
Drives: 90mitsu
Re: installing a 1g 4g63 in a 2g?
i think youll need a cas harness!!! i got one i will throw in with car....
Old 06-30-2007   #3
http://www.magnusmotorsports.com/tech/1gina2g.pdf
Old 06-30-2007   #4
green hornet
sound's good
Old 06-30-2007   #5
This has been talked about almost as much as Allan's scorchers on the net. Search around. Magnus and others have posted plenty about the needed parts and tricks. RRE has a very nice plug and play harness to hook up the 1g CAS.
Old 07-03-2007   #6
green hornet
ok i read the link and do i need a 2g tranny for the swap? if so i have a 1g manny-tranny if eny one wants to swap for a 2g manual.
also is all the ECU re-wiring needed or is that only if i throw codes?
i am VERY new to 4g63's, i own a GS so i am in need of lots of help
Old 07-03-2007   #7
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Do a search and it will get you very far. Alot of people have very informational posts on this process.
Amsoil Dealer
