Old 07-05-2007   #1
Onefast99gsx
Question Took car for a ride tonight for the 1st time BUT....
Hi guys- I had some non motor related delays. Starting the motor for 1st time went excellent. I did (3) 10 sec intervals of turning it over without the plugs, inj wires unplugged and also the crank sensor. It primed really fast. When I went to start it for real, it started as if I just shut the thing off seconds ago...
Took car for a ride tonight for the 1st time around the block BUT.... I need to get the crank bolt torqued to spec (87 lbs). I just torqued it with my cheapy impact that wouldn't even break the same bolt loose months back. So anyway, i limited my ride to just around the block. I would have thought that having the front wheels on ramps, back wheels on the ground & blocked, car in 1st gear, e-brake on...that I would have been able to tighten that bolt. When I torqued it the whole motor wanted to turn over, yet the car wasn't moving when the crank pulley was turning which I thought was really odd. Is that something to do with the Diff or something? While in gear, I couldn't push the car at all so why is that I couldn't tighten it?
So how do you guys tighten that bolt? The book shows a spanner type wrench holding the pulley while using the torque wrench on it. I don't know anyone around here that will have that spanner wrench.
Thanks guys...
