Old 07-07-2007   #1
rusted to f*ck nuts on fuel pump cover solutions
i am having the worst time with this stupid little area. The cover was so rusted i cant even describe it. After much PB blaster, chiseling and dremeling i've gotten most of the nuts off successfuly. I also broke one, yay. The last two are giving me insane troubles, even though i've been PB blasting them for weeks.
I was THINKING about applying some heat to these nuts, but its obviously in the worst part of the car for such an idea.
I've also thought about just breaking the studs, then drilling them all out and holding the cover down with rivets when i reinstall it.
I dunno, i'm looking for advice or a planB. Spare gvr4 fuel tanks are hard to come by and even more $$$ to ship.
Dont tell me to run a fuel cell either.
Old 07-07-2007   #2
b00stcreep21
I hate everyone
b00stcreep21's Avatar
Re: rusted to f*ck nuts on fuel pump cover solutions
I would CAREFULLY apply some heat to them. I've had the best luck with a small butane torch. They're not going to need much. Just a little bit around the outside of the nuts
Old 07-07-2007   #3
Yea, a small torch works wonders.
-A. Swift
Old 07-08-2007   #4
drop the tank, and play with it outside the car! Why would you rivet the lid back on? what if you have to take it back off, you really want to drill them all out?
Old 07-08-2007   #5
I would like nothing better.
Old 07-08-2007   #6
xveganxcowboyx
Wanker
xveganxcowboyx's Avatar
Drives: 95 M3
I just put self tapping screws back on mine. You can do one better and JB Weld new studs facing up. Just be sure to get a magnet under while you are drilling them out.
Old 07-09-2007   #7
Plasma cutter
Old 07-09-2007   #8
Just put a fuel cell in, or us a plasma cutter it would be fine. My tank only had 3 nuts left, use some RTV or window weld when you put it back together.
Old 07-25-2007   #9
gofastman
James Bond... James Bond
gofastman's Avatar
Drives: 95 Jeep
heat the nuts up and touch a parafin candle to them, the wax acts like a penitrating lube, plus the heat helps knock em loose.
-David C.
