Old 07-24-2007   #1
crazy_skier
A.E.K.Δ.B
crazy_skier's Avatar
Beer Dude 2 Champion!
Drives: 1994 Suburban
Pos Act Pressure Plate
So I purchased one of the "new" act pressure plates which has around 1500 miles on it and my clutch stopped disengaging. So I dropped the tranny and the pressure plate fingers were stuck in, and once I disconnected the pressure plate they popped back out. Do I risk trying to re-use it or should I purchase a new one. I am going to try and get it warrantied but I purchased it about 105 days ago so I'm a few days out of luck.
Any help is appreciated. Thanks Ryan
Old 07-24-2007   #2
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: Pos Act Pressure Plate
They are suppose to be "stuck" in when the PP is on the flywheel....
When you push in the clutch, it pushes the fingers in even further to disengage.
Originally Posted by shoutbox
Old 07-24-2007   #3
blageo23
AWD4G64
blageo23's Avatar
That is totally normal operation.
Old 07-24-2007   #4
crazy_skier
A.E.K.Δ.B
I know that they are supposed to be part way in, so I'll see if anything fixed itself by reinstalling everything.... hopefully as I'm sick of working on this thing (especially since I dont own it anymore)
Old 07-24-2007   #5
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Well if it doesnt disengage, there is an issue with the clutch master/slave/fork/TOB.
Seeing you are staying the fingers are "stuck" in. Well "in" is disengaged.
When installing, the fingers should be damn near straight. To disengage it, you need to push the fingers towards the clutch disk/flywheel.
Old 07-25-2007   #6
There are some more possiblities too. Bad disk, loose flywheel bolts or crankwalk are the ones I can think of.
Old 07-26-2007   #7
crazy_skier
A.E.K.Δ.B
could it be a defective pressure plate, the disk is like new and there is not crankwalk and I went through the hydralics but I could have missed something I guess. I'll let you know what I find tommorow
Old 07-26-2007   #8
A PP doesn't usually go bad like that. It is much more likely that it is the disk. For a PP the fingers can get weak and not hold the power or the rivets can come out and it physically starts to fall apart, or the inner surface gets trashed and it slips also. Are the springs on the disk ok? They like to die pretty often and get stuck in there.
Old 07-26-2007   #9
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
Check your TOB. My OEM TOB was in a million pieces and I didn't know it was in a million pieces until I unhooked it from the fork and it just disintegrated. It killed my pp.
Old 07-26-2007   #10
dragonforce
I repaired 3 1G clutch pedal in last few years. they start to wear out notch at the end of shaft mounted to pedal. you can repair it by welding the end or just get the used pedal assembly.
dragonforce is offline   Reply With Quote
Old 07-26-2007   #11
crazy_skier
A.E.K.Δ.B
I'm in a 2g but thanks dragonforce. I havent worked on it with the heat so we'll see how she is in a few days.
Old 07-28-2007   #12
2.SlowES
2.SlowES's Avatar
Check the output shaft the TOB rides on. I had one wear so badly that the TOB couldn't ride over it, which then wouldnt allow the clutch to engage fully.
2.SlowES is offline   Reply With Quote
Old 07-30-2007   #13
It sounds like a disengaging issue. Bent throw out fork, bad pivot ball, bad clutch master or slave cylinder, miss adjusted clutch pedal, floor mat in the way.
Old 08-03-2007   #14
Did you try bleeding the clutch system? Something that simple might have kept you from pulling the trans back out. I had the same problem recently, thought the fork might have punched through on the pivot ball, bled the system and it is working perfectly.
Old 08-04-2007   #15
x-pride
x-pride's Avatar
Did you ever find out what caused you clutch from disengaging?
