Old 08-06-2007   #1
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
GST to GSX Fuel Sending Unit Wiring
I am doing a Spyder AWD swap and am almost done. All I need is how to wire the awd gas tank wiring to the fwd wires on the car. I read womewhere that the wires are the same but wanted to make sure. Thanks for the space.
Amsoil Dealer
Old 08-06-2007   #2
Re: GST to GSX Fuel Sending Unit Wiring
I dont see how different they could be, you will have a power/ground for the fuel pump then wires for a fuel level gauge and low level light in both fwd and awd dsm's.
Old 08-06-2007   #3
Enes
Enes's Avatar
# On the AWD Passenger Side Fuel Pump/Sender Connector
1. Thick blue/black wire is fuel pump power and is connected to the same wire on the 2 pin FWD fuel pump harness
2. Thick black wire is the fuel pump ground and is connected to the same wire on the 2 pin FWD fuel pump harness
3. Thin yellow/black wire is the sender feed to the second sender and is wired into the yellow/black coming from the other sender
4. Thin black wire is the sender ground and is wired into the ground wire on the FWD 3 pin sender harness
5. Thin yellow wire is the low gas light wire and is wired into the non-yellow wire on the FWD 3 pin sender harness
# On the AWD Driver Side Sender Connector
1. Thin yellow/black wire is connected to the yellow black wire coming from the passenger side sender
2. Thin yellow wire goes to the fuel gauge and is connected to the yellow wire in the FWD 3 pin sender harness
