Old 08-12-2007   #1
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
blew the weld again
So I posted a while ago about my turbo being extra laggy and then found out that I had blown the weld in my o2 housing. I've got an external wg on my manifold which allows for the top hole in the o2 housing to be welded. Anyways, I had that rewelded after I blew it the first time, and I think I've blown it again. I haven't yet pulled the turbo and taken everything out to make sure because I am way too lazy and don't want to. I also don't see the reason considering that has to be the problem. My only question is, should I just have it rewelded again or what? I mean I dont have the time or money to keep rewelding this stupid thing. What are you other externally gated guys doing? I've had a few ideas, lmk what you guys think.
-Fill the whole with melted steel and let it harden inside so it's thicker than just an 1/8 inch steel plate.
-lse has a 02 housing they sell that is just one big opening, but idk if that would work with an external wg.
Here's a pic of what it looked like before and what I assume it looks like again now.
pics or gtfo
Old 08-12-2007   #2
b00stcreep21
I hate everyone
b00stcreep21's Avatar
Re: blew the weld again
LSE's o2 housing wouldn't work with that housing. You can either get it re-welded again, buy a new housing (actually not that expensive), or run an 02 eliminator that blocks off that port. There's plenty of options out there
Old 08-12-2007   #3
HiImBrian
HiImBrian's Avatar
I didn't really think lse's would work.
What would I need a new housing for? I'd just have the same problem with that one wouldn't I?
I like the sound of an o2 eliminator but idk anything about it. I'll start searching now, but feel free to fill me in while I look thanks
pics or gtfo
Old 08-12-2007   #4
HiImBrian
HiImBrian's Avatar
Figured out what it is. Basically it's either a tubular o2housing with a dead end pipe or i found a few that actually kinda run the o2 hole right into the other one and increases turbo spool. This sounds like a great idea but they are a little pricey.
pics or gtfo
Old 08-12-2007   #5
b00stcreep21
I hate everyone
You can get a new housing that doesn't even have that hole in it in the first place from precision
Old 08-12-2007   #6
HiImBrian
HiImBrian's Avatar
ooo That sounds a little cheaper than this
pics or gtfo
Old 08-12-2007   #7
b00stcreep21
I hate everyone
that still wouldn't help your situation. You need that port completley blocked off, that still leaves it open
Old 08-12-2007   #8
HiImBrian
HiImBrian's Avatar
^Your completely right. Haha I've I got what I pictured I would be way worse off than I am right now. Man I'm an idiot.
When you said precision has the o2 housing i need do you me pte? Cus I can't find their website for the life of me
pics or gtfo
Old 08-12-2007   #9
b00stcreep21
I hate everyone
Mmk, i liked about the housing. Lol. My bad. Basically, an easy way to do it would be to just have a downpipe flanged that covers up the port completley, and just has a bend coming off for the turbine wheel discharge. Basically what you have pictured above, just without that little connecting piece by the wastegate hole
Old 08-12-2007   #10
HiImBrian
HiImBrian's Avatar
not really. I don't have a down pipe. It's a custom turboback exhaust
pics or gtfo
Old 08-12-2007   #11
b00stcreep21
I hate everyone
Sorry, post edited
Old 08-12-2007   #12
iceminion
iceminion's Avatar
not sure if this would help you, but I am selling something that may work for you
http://dsmstyle.com/forums/showthread.php?t=16469
building a 3000GT AWD Turbo.
Old 08-12-2007   #13
96tsiawd
96tsiawd's Avatar
nice "bump" on the tial WG sale- hows the GVR4?
96tsiawd is offline   Reply With Quote
Old 08-12-2007   #14
Bring it to me and I will weld it up for you. It won't come off when I am done with it
Old 08-13-2007   #15
gofastman
James Bond... James Bond
gofastman's Avatar
Drives: 95 Jeep
any one know if you can you weld cast iron with silicon bronze?
-David C.
Old 08-13-2007   #16
Bronze isn't going to take the heat well. Melting point is like 1150 degrees.
Old 08-13-2007   #17
HiImBrian
HiImBrian's Avatar
Well jet I'd take it to you but I'm planning on running close to 30 psi and idk if I trust it to hold. I wanna fill it up with steel if possible.
pics or gtfo
Old 08-13-2007   #18
Yeah, you're right. I don't know WTF I am doing.
How do you plan on filling it up with steel? It's just a block off plate.
Old 08-14-2007   #19
Just get the correct exhaust housing.
Old 08-14-2007   #20
https://secure.buschurracing.com/cat...roducts_id=420
That is what you are looking for. An O2 housing with a flange that completely blocks off your wastegate port.
