Old 08-15-2007   #1
Enes
Enes's Avatar
polishing vibrator
You can polish parts a lot quicker and professionally! It is out of thick metal, a little bit of surface rust is pretty much nothing, with a can of paint you can make it look brand new. I will most likely end up doing that myself before its sold.
It was used by a local shop until it closed. It has a new motor in it, and comes with 180 Pounds
of stripping/polishing media, that alone is worth over $800
Dimensions:
29" x 18.5" x 19.5"
corner to corner you can fit in a part thats 34" long!!
The bad:
the lining around the drain started pealing a bit away but i will fix that before it is sold.
$700 gets you everything.
More Pics here
-Enes
