Old 08-20-2007   #1
Thor06
11 Seconds to Freedom
Thor06's Avatar
Cleaning out the garage, lots of stock, some aftermarket!
Hey all, I am trying to get rid of my excess stuff to free up some space in my garage. All are in good shape and good working order unless otherwise noted. I have/can get pictures of all of this stuff, but there is just far too many to post. Picture requests and inquiries should be directed to theflyguy11@hotmail.com as it is the easiest/fastest way to get ahold of me, but PM or post will work as well. All items will be shipped within a day or two of cleared payment via Fedex or USPS depending on the item and day. All prices are "Or Best Offer" and not including shipping. Thanks everyone!
- 1ga driver side turn signal $15
- 1ga passenger side turn signal $15
- 1ga driver side bar light $15
- 1ga passenger side bar light $15
**Or full set for $50**
- (2) 1ga driver side tail light $20 each
- (2) 1ga passenger side tail light $20 each
- 1ga center reflector for the tail light $15
**Or full tail light set for $50**
- SMIC, looks good $20
- Stock 2g manifold, great shape no cracks $50
- Ported 2g manifold, 7cm outlet, looks good! $75
- (2) Engine wiring harnesses, both include starter harness, 91 turbo AWD manual, should work for 92-94 as well $125 each
- Passenger front axle, should be rebuilt $20
- Driver front axle, great shape $40
- Power steering pump $15
- (2) 91 cam angle sensor, pulled from working cars $25 each
- (2) 1g throttle bodies, pulled from turbo 91 cars, all sensors good! $30 each
- (2) 91-94 coil packs, worked fine $30 each
- (2) 91-94 transistor packs, worked fine $20 each
- 1g fuel rail $10
- (3) Stock 1g intake manifolds with EGR valves $20 each
- 1ga blue rear bumper, great shape but its been sanded in prep for paint $30
- 1ga blue hood, straight, no dents or rust, but sanded as well $50
- (2) 1g Drivers side motor mount $15
- 1g tanny mount $10
- 1g front engine mount $10
- 1g rear engine mount $10
**Or $40 for the whole set**
- (2) Stock 1g AWD flywheels $30 each
- Centerforce dual friction clutch, used but disk has a good amount of meat left on it $150
- (2) 1g turbo clusters, both look great $30 each
- 1g MAF $15
- 1g radiator with fans $50
- 1g working alternator $25
- 1g head, complete deck to valve cover, ~50 miles on the planed head and valve seals, high temp blue paint with polished letters $150
I know its a reach, but I am looking for some stuff if you would rather trade or trade plus cash. Stuff I am looking for:
- DSMlink
- AFPR
- 850cc+ injectors
- aftermarket BOV (preferably a Type S, Type RS, SSQV)
- ACT 2600 or equivalent
- chromoly flywheel
- front mount setup
Thanks for looking!
