Old 10-04-2007   #1
ARP Flywheel bolts
Alright, I found a good deal on the ARP Supra flywheel bolts. These are the same a DSM ones, but 1/4" longer. They allow more thread engagement and are usually used with a spacer from an auto DSM. The spacer will also help prevent them from loosening and is only $7.
The price is great per bolt from the place I am getting them from, but shipping isn't. I am looking for someone to split shipping costs. $28 for a 6 bolt or $32 for a 7 bolt. I could meet someone at a Bee's get together to deliver them, or I am in Fridley.
Old 10-04-2007   #2
blageo23
AWD4G64
blageo23's Avatar
Re: ARP Flywheel bolts
Hey looks like im going to be taking apart my car and maybe these would be a good idea. I am interested.
Old 10-04-2007   #3
Atta boy, now get it done before the dyno day!
Old 10-04-2007   #4
blageo23
AWD4G64
blageo23's Avatar
Yah we'll see. When can you get them here by? Also do you have a part number for the spacer?
Old 10-04-2007   #5
I should have them in a few days I think, sometime next week I am sure. I have a thread in the Brookdale section for the spacer, Nick posted the part number there. He knows which one to order now.
The cheapest I have found these for at other places is $43 without shipping.
This is what I am using to try and fix the exact same problem you are having. Mine has happened 6 times though!!
Old 10-04-2007   #6
blageo23
AWD4G64
blageo23's Avatar
Count me in!
Old 10-04-2007   #7
Sweet, I will order them tomorrow if anyone else wants in.
Old 10-04-2007   #8
blageo23
AWD4G64
blageo23's Avatar
I just reread the first post and im a little confused. How much are these going to cost me? $28 shipped?
Old 10-04-2007   #9
Yes, if you have a 6 bolt. Besides the place I found them at, the cheapest was $43 online. So you will pay $28 shipped if a 6 bolt or $32 shipped for a 7 bolt.
Old 10-05-2007   #10
v8klla
v8klla's Avatar
Jet,
Check these out:
http://www.maperformance.com/store/p...cat=577&page=1
I should be able to get you a little better deal too if you are interested We just used these in the RX7 and there was no need for a spacer, they are from a Toyota 3SGTE platform. It also comes with 8 bolts, so it would work for the 6 bolt or 7 bolt platform.
Chris
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 10-05-2007   #11
blageo23
AWD4G64
blageo23's Avatar
Well either way you go I want a set!!
Old 10-05-2007   #12
Thanks Chris, but .020" isn't going to do much. That is the width of 5 human hairs. These other ones are .230" longer. The spacer plate is supposed to help on its own also.
Old 10-06-2007   #13
v8klla
v8klla's Avatar
Yeah that's a typo, I meant .20" lol.
Chris
P: 763-545-3800
Old 10-06-2007   #14
Hmm...change your web page If I would have known they were .200" I would have ordered them from you guys. The order is already placed though.
Old 10-19-2007   #15
Just to update this, the fucking Supra flywheel bolts don't fit, you need the ones for the 3GSTE. Stupid ass on NABR posting bad info.
Old 10-19-2007   #16
well that blows. can you just add on another spacer plate?
Old 10-19-2007   #17
twack
It was a auto get over it
twack's Avatar
uh oh you going to be ready in time
Old 10-19-2007   #18
Supra uses 10mm bolts, not 12mm. Now I just got back from Brookdale and they fucking gave me flywheel bolts for an automatic. An automatic doesn't have flywheel bolts. This is pissing me off.
Old 10-19-2007   #19
blageo23
AWD4G64
blageo23's Avatar
I was woundering why I didn't get a call. If you find ones that work let me know.
Old 10-20-2007   #20
Alright, this isn't really the right spot for this, but if someone finds it in a search I will finish this out. I ended up using the stock Mitsu bolts for an auto car. You will need to check the depth of the threads to make sure it will work. If you screw it in all the way and have less than .660" from the top of the bolt head to the end of the crank, then you are ok and can just use the longer bolts and auto spacer plate. Note, this is for a twin disk with a .315" thick flywheel (standard PTT). It *should* work with a regular clutch too, but double check the measurements. I am pretty sure the stock flywheel is thicker so there shouldn't be an issue.
Also, make sure you have a dowel pin in the crank. Mine didn't and that was probably the main culprit of why mine loosened up.
