Old 10-19-2007   #1
Really quick question
Planning on swapping over my fuel pump rewire kit next week (possibly tonight). I have the battery relocated to the trunk, So technically i should just have to wire the positive like 3 feet right? This could be really RLY easy.
Old 10-19-2007   #2
twack
It was a auto get over it
twack's Avatar
Re: Really quick question
Yup and if you got a battery cutoff switch in the back it makes it that much easier to setup
Old 10-19-2007   #3
why would a battery cutoff switch make it easier?
Old 10-19-2007   #4
Old 10-22-2007   #5
What ever you do, put an inline fuse on the wire as close to the battery as possible. You don't need another fire sale.
Old 10-22-2007   #6
+1, not just to the fuel pump, the whole positive connection to the battery!
Same reason why you'd need a battery cutoff!
Old 10-22-2007   #7
Exactly, either a big breaker or some type of fuse/switch that will disconnect the battery from the circuit of there is a short. Any other direct feeds off the battery should also have inline fuses.
Old 10-22-2007   #8
I usually like to take a peice of wire and connect it to the positive and let it dangle right over the negative, i like living life on the edge. lol
