Old 10-28-2007   #1
Center diff/4 spider gear ???S
Well i trust you guys, cause you always give good advice.
I need some info on the following. i have a '92 tranny with stock T-case and welded center, i want to buy a 4 spider and someone is selling one out of a '90 how can i check that it will fit?
Thanks
Aaron
(oh yeah, hopefully the panda look will be gone next year)
Old 10-28-2007   #2
Re: Center diff/4 spider gear ???S
gone? why? what for?
-A. Swift
Old 10-28-2007   #3
Thanks
Aaron
I have a '90 4 spider for sale as well if you can figure out if it can work.
Old 10-28-2007   #4
I guess the panda look will stay.
As soon as i can figure out if it works, i will hit you up.
Old 10-28-2007   #5
I am pretty sure the center diff is the same.
Old 10-28-2007   #6
I need some good reassurance before i pull my tranny and try this one.
Old 10-28-2007   #7
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Check this out and see if this helps you for the center diff. The one I have is like the one on the right.
http://www.jackstransmissions.com/ds...e526168a7b366e
Amsoil Dealer
Old 10-28-2007   #8
No linky!
Old 10-29-2007   #9
so far my research has found that 91+ center diffs will work with each other but 90s are a one off.
Old 10-29-2007   #10
95talonracer
Finally Tuned...
Drives: Spyder GSX
There I added the link. http://www.jackstransmissions.com/ds...e526168a7b366e
Amsoil Dealer
