Old 10-29-2007   #1
mitsu'97
Drives: 1994 Honda Civic EX SOHC VTEC!!!!
Send a message via AIM to mitsu'97
Might buy a DSM
I was thinking about buying a Talon TSI AWD but the shop that i bring my cars to said not to becuase the AWD system and the timing belts are kinda unreliable and if the timing belt breaks then the engine is shot.
Has anyone had to deal with this stuff and if you do own one have you put alot of money into repairs?
mitsu'97 is offline   Reply With Quote
Old 10-29-2007   #2
123abc
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Re: Might buy a DSM
1. I would recomend not using it as your only car.
2. A timing belt job should be one of the first things you do to it once you get the car, along with checking all the regular maintenance stuff
3. Hell yes get it!
What year?
Old 10-29-2007   #3
Re: Might buy a DSM
The timing belt usually doesnt break, it usually just skips teeth if not torqued correctly or is worn or loose. And usually when that happens you just bend some valves and need to get your head rebuilt or replaced.
The AWD transmission sometimes takes a shit on people, but thats just more of a reason to send it to Shep or some other shop to get a nice durable race build. The main thing you have to watch out for is crank walk. I usually like to tell people with 92.5 years and up to change their oil often around the 90,000 mark all the way up to the 120,000 mile mark, this way the oil squirters for the pistons and crank stay unclogged and will usually detur the crank walk. Magnus actually did a study on that and found that most likely the cause of crank walk is the oil squirters being clogged or loss of oil pressure.
I would definatly suggest getting the car, they are great cars, im on my third, some of the dsmstyle members are on over 7 of these cars.
Old 10-29-2007   #4
Re: Might buy a DSM
The AWD system is one of the strongest around, just make sure to take care of it and maintain like anything else.
If the timing belt snaps it will do some serious engine damage, it is an interference engine just like pretty much everything else being sold these days. Keep your timing belt replaced every 60k by a competent shop and you'll have nothing to worry about.
I have owned 5 or 6 DSM's now and not a single one has ever left me stranded, I also maintain my cars very well and take care of issues as they arrise.
Another good word of advice to you, don't go to just some shop down the street from you. Take a DSM to a shop that has experience working on and building these cars. Not only will you get better service and expertise, but generally the labor and parts are cheaper.
Old 10-29-2007   #5
Re: Might buy a DSM
QFT. When i moved to cali i decided i wouldnt take my car to any shop, mainly because i had heard bad things about pretty much every shop in the area. At least in MN you guys have awesome DSM Shops that are dependable and have been around the scene enough.
Old 10-29-2007   #6
Scrmegl
Brian
Scrmegl's Avatar
Danger Wheels Champion!
Drives: '98 TSI AWD
Re: Might buy a DSM
I completely agree with the above. Be willing to do the proper maintenance. I have had about 3 solid years of dependability with mine. Just make sure the one you buy is in good enough shape for the level you are willing to work on or invest into the car. Ask someone who knows these cars to look at it with you if you can. Good luck!
Old 10-29-2007   #7
Re: Might buy a DSM
Keep up on maintenance and you will be rewarded with one of the funnest and fastest cars on the road for the price. Drop some cash and you will be laughing at vipers and 911 turbos in no time!
Old 10-29-2007   #8
Re: Might buy a DSM
DSM's are the best bang for your buck if you're looking for a fast car!
Old 10-29-2007   #9
Re: Might buy a DSM
buy it they are great cars to have. I own 4 right now. It is the best car for the money for a awd turbo car
Old 10-29-2007   #10
mitsu'97
Re: Might buy a DSM
Ok,
Thanks this helps out alot, the only thing that i am worried about is that the person who is selling it does not want me to bring it to the shop where i bring my cars but that may be because it is a 1/2 hour away.
Old 10-29-2007   #11
BLaCk_1cE
BLaCk_1cE's Avatar
Drives: TB IX SE
Re: Might buy a DSM
Originally Posted by mitsu'97 View Post
Ok,
Tell him to suck it up.
Old 10-29-2007   #12
mitsu'97
Re: Might buy a DSM
Rogers to Roseville is a 1/2 hour if there is on traffic whatsoever and also to someones post earlier this car would probably be my only car because i would have to sell my Mitsubishi Mirage to purchase it and to keep up with the maintenance.
Old 10-30-2007   #13
Re: Might buy a DSM
What year are you looking at? The 1g's are a little more solid than the 2g's, but the condition of the car can vary drastically with cars of this age. I don't know why someone wouldn't let you take the car to a shop to have it checked out, that doesn't sound right.
Old 10-30-2007   #14
mitsu'97
Re: Might buy a DSM
The guy sounds really nice and he will let me test drive it and stuff but he doesn't want me driving it to Roseville to have it looked at because im guessing it is too far away maybe.
And it is a 1g, a 1991.
Old 10-30-2007   #15
Re: Might buy a DSM
Take the car to DP Performance then, they are right in Rogers and I'm sure they'd be willing to give it a once over for a reasonable price. They are actually one of the board sponsors.
Old 10-30-2007   #16
mitsu'97
Re: Might buy a DSM
do you have the phone number for DP Performance?
Old 10-30-2007   #17
Re: Might buy a DSM
They have their own section on this board, check there for all their contact info.
Old 10-30-2007   #18
Re: Might buy a DSM
Otherwise we can also do full service vehicle inspection but we are a bit out of the way (ramsey).
Old 10-30-2007   #19
Re: Might buy a DSM
Does that stand for "Double Penetration" Performance?
Old 10-31-2007   #20
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Re: Might buy a DSM
I am with everyone else on go and buy it. It is a great car. Of course when you are asking a mitsu club about buying a mitsu, what kind of answer do you expect?
Like everyone else said, do the maintenance on the car! Don't buy this car with all of your money and then become broke. Have some money on the side so you can get some maintenance things done. Maybe have someone change the timing belt out so that you know it is properly done.
Check shaft play in turbo
is it stock or has it been modded? It is rare to find one without mods these days
Change all fluids to good quality (will fix a lot of tranny problems)
There is a big list on the net on what to look for.
