Old 11-02-2007   #1
something weird that could be useful.
Well i have upgraded to a scm61 with an external wastegate with 23psi spring inside.
Car = 158k longblock. mods to support 61.
The weird thing is the new turbo runs the exact same boost levels as the 16G, when i mean exact i mean move the boost graph to the right about 1200rpm and there is the new turbo, but it makes the same power.
Same spike, same dying off, well it only dies to 20-21, but then at 7k it starts to pick back up again.
I am waiting for the c-clamps on the comp. cover to arrive, i am gonna rtv, put on the clamps, if that doesn't fix my problem, i have no idea what will fix it.
Aaron
(i figured something for the archives, if nothing else.)
Old 11-03-2007   #2
Re: something weird that could be useful.
what's your point, exactly?
I would hope the power levels are higher, but yea, assuming nothing else is changed, i'd guess the same as you posted. power falling off and such.
-A. Swift
Old 11-03-2007   #3
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
I don't really understand your problem either but that's cus I'm drunk. But you should probably buy my HK$ external wg setup! That'll fix your problem w/e it is haha
pics or gtfo
Old 11-03-2007   #4
You either have a serious boost leak, or something like a bad lifter.
Old 11-03-2007   #5
+1, something else is goofy I think man! Probably the boost leak like you said. Show us before/after dyno plots when you get time
Old 11-03-2007   #6
I think you need a new flamidation valve.
Old 11-03-2007   #7
The car made 8hp more and lost a lot of tq.
drunk people that don't know anything don't bother posting.
I guess my point is that the car is at the same boost levels, but it didn't make more power.
i will continue this, its supposed to be more for archive use as its a weird problem that will hopefully be solved soon.
Old 11-03-2007   #8
If it is for archive use, then you should post up a full description of the problem.
Old 11-04-2007   #9
And not be a jackass to those trying to help.
-A. Swift
Old 11-04-2007   #10
^Or those being jackasses could just fuck off.
Old 11-04-2007   #11
--againstmy better judgement--
